DIY: g35 coupe trunk removal and rear seat removal for trunk swap
+1 I need to leave my hinges on my body to attach a new trunk to (instead of swapping two trunks that both have hinges)
Used proper torx head but still stripped..... I guess I now have to drill out/ grind off and try and find new bolts. crap
I'm 100% sure you can just remove the trunk. Howwwwwwwwwwwwwever, NO ONE in the history of the G35 community and internet (apparently) has done this and documented it. I'm removing my trunk soon (already attempted it once last week) and will take pics and post something. I can tell you that you, at the very least, have to remove the carpeting/panel on the decklid. There's also 3 10mm nuts to unscrew. THAT'S where it gets complicated. There's some plastic pieces in between the trunk lining that present a bit of a problem and I don't know how many there are. But, as stated, I'll find out and post it.
I did my trunk swap about 2 months ago and read about how other ppl were stripping the torx bolts. What i did was (ghetto, but worked) use the proper torx size with a small craftsman rachet and clamp that to the top side of the trunk using a C-clamp (put some thick paper or similar between the C-clamp and the trunk to avoid scratching your paint). Once you get the torx at the correct angle and tighten the C-clamp, then VERY carefully and slowly begin turning the ratchet. I heard a pop when my bolts broke loose so they're on tight. BTW i strongly suggest you replace those bolts with a button head hex (i think it was an M6 screw) when you put it all back together.
#30
