Angel gauge install help anyone?
Yeah so i ordered the angel guage mod off of ebay that came with zero instructions....i ended up finding tons of "how to" replace a guage cluster...so that was no problem. I got the new Guages in but i just can't figuring out the wiring. I have no idea where to connect the black and red wire to and there is also three other clamps....My only guess is the interior fuse box...but i don't wanna go ****ing around and mess this up....Has anyone installed these on their G? If so help would be greatfully appreciated...or a point to the right thread b/c i can't find that either....
It came out good...I put it in when i put my Kenwood DNX-6140 in..Had to take the dash completly apart..But after a couple tries it became very easy....I hear a buzzing noise when i flip the switch to a different color option..i'm gonna try attaching the hot somewhere else, see if that fixes it....
install
the red is positive and the blk is neg like normal, just hook it up to any power supply when ign. is on. the other 3 connectors is different lengths where you can connect the gauges too. its real easy. i had to take off my gas needle because if the blk trip odometer needle. just make sure the other needles are facing up while installing the faceplate, it will make it alot easier. by the way you will get a buzzing niose when you switch the color to cool blue. it looks ok while on but i like it better white. good luck with the install. it not hard at all..
no, the buzzing is just the way they designed it. i use the white color, no buzzing. im taking mine off and leaving my blue gauges
djreinx
Engine - Electrical
12-10-2015 01:48 AM
TWASkyliner
08-01-2015 11:43 AM
