DIY: Door sill/trim removal?
Do you know were I could get some pics with the sill off and how many holes there are and such. I might want to pay to get them filled in..ect
They are clips. You have to be careful (I used a plastic trim tool to depress the clip part so as not to break them). When you pull the trim piece you'll see that it has two pieces that need to be depressed (on each side of the clip) in order to remove it. It was kind of tricky, but I found that if you just press in one side it usually will pop out.
Danielek
05-01-2022 01:28 PM
