*DIY Paint Headlight insides* V36
#32
hopefully you 2nd gens are doing this DIY (https://g35driver.com/forums/v36-diy...lens-swap.html) as well since your headlights are already open.
#33
NEXT STEP IF I DECIDE TO CRACK OPEN THE HEADS AGAIN = http://www.automotivelightstore.com/...lehalokit.aspx
#36
#37
#40
#41
On most of them the stock sealant just reheated and pressed really hard will do. But now I always add window sealant I get from orielly's. Heat up the exsisting sealant up a lot around the black housing and on the clear lense so everything is hot to the touch, then lay a tiny bead of window sealant in the dip around the black housing, then quickly press the clear lense and the housing together as tight as you can working your way around it, tighten up the blubs, then press them together again working your way around the headlight. Never had any issues leaking when I used this method.
#43
