*DIY Paint Headlight insides* V36
Old 06-20-2011, 08:29 PM
djfarhan's Avatar
^ i liek
GXXXV X (06-20-2011)
  #32
Old 06-20-2011, 08:43 PM
VstyLe09's Avatar
hopefully you 2nd gens are doing this DIY (https://g35driver.com/forums/v36-diy...lens-swap.html) as well since your headlights are already open.
  #33
Old 06-20-2011, 10:23 PM
GXXXV X's Avatar
i figured theres no point since i get minimal light output anyway since i have 10000K heads (and i dont really care about the cut-off point), but i will get those for when i do the bumper fog light mod for some bright azz fogs lol
NEXT STEP IF I DECIDE TO CRACK OPEN THE HEADS AGAIN = http://www.automotivelightstore.com/...lehalokit.aspx
  #34
Old 06-20-2011, 10:55 PM
das stig's Avatar
Looks great! Glad I could help
  #35
Old 07-12-2011, 10:27 PM
05slateg's Avatar
nice write up...
  #36
Old 11-29-2011, 09:32 AM
jbrueggemann84's Avatar
This is a fantastic DIY tutorial. I am at work now, but cannot wait for the weekend to do this! I posted earlier about adding a LED strip to the lights but this is a definite!
  #37
Old 01-20-2012, 05:46 AM
leoverte's Avatar
dammmm...i want black housing headlights...but im waaay to scared to take apart the headlight housing...ive taken my headlights out a million times for hid bulbs, but just chicken to try and paint my headlights...lol..dam
  #38
Old 05-01-2012, 10:12 PM
mavs1balla's Avatar
Wow...looks absolutely amazing...Im too scared to try this man..but i love the look SO much
  #39
Old 05-01-2012, 11:44 PM
kristof's Avatar
I need to do this ASAP. I done this mod to my last car along with a retrofit and loved the look.
  #40
Old 06-19-2012, 11:17 AM
ughhhead's Avatar
Yea I did this to my eclipse and prelude way back in the day and I had some wicked condensation in the eclipse headlights. What kind of sealant do you use? Those look super nasty though
  #41
Old 07-31-2012, 05:46 PM
das stig's Avatar
On most of them the stock sealant just reheated and pressed really hard will do. But now I always add window sealant I get from orielly's. Heat up the exsisting sealant up a lot around the black housing and on the clear lense so everything is hot to the touch, then lay a tiny bead of window sealant in the dip around the black housing, then quickly press the clear lense and the housing together as tight as you can working your way around it, tighten up the blubs, then press them together again working your way around the headlight. Never had any issues leaking when I used this method.
  #42
Old 11-15-2014, 02:21 AM
FlashG35S's Avatar
So question, the chrome part around the projector lens, Is this able to be removed from the lens to be painted?
  #43
Old 04-11-2016, 03:20 PM
Lucky-G's Avatar
Decided to give this a whack last night! I went ahead and removed the projector shroud also, along with the bucket for the turn signal, and the marker light "bullet". I almost did the fog light bullet, too.
lil beezy
Lights
12-23-2015 05:25 PM
linedr89
Engine - Power Adders
10-04-2015 07:29 PM
cmesidewayz
09-29-2015 09:28 PM
johnadlertech
Lights
09-04-2015 12:35 PM
Quick Reply: *DIY Paint Headlight insides* V36
