MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Brakes & Suspension (DIY)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 02-06-2008, 02:37 PM
Quote:
Originally Posted by Steel Blue
I assume this is the same way to change breaks on non-Brembo?
dude.. read the title again.
__________________
i dont give a duck.
Old 02-14-2008, 10:58 AM
waijai's Avatar
i.love.gold
2003 Infiniti G35 Coupe
Send a message via AIM to waijai
non-Brembo is easier
You just have to take out one of the caliper bolts and swing the caliper away
__________________
Team16NiSS.org | tunedperception.com
Sponsored by: Meguiars : Dunlop : Valvoline : Autometer : iForged : Kicker : GS Motorsports : Top Speed Auto : Zeetoyz : J&M Paint & Body : NOS Energy Drink
Old 02-19-2008, 10:42 PM
Send a message via AIM to bythabay
and here's some video of this procedure:
http://www.youtube.com/watch?v=LZLX3jkgsJw
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html
Old 02-20-2008, 02:26 AM
accordfreak's Avatar
Quote:
[/url]
" ohhh yeah" " alright" lol. nice video
__________________
tb g35 cpe 06 headlight mod..... http://www.g35driver.com/forums/showthread.php?t=103689 BLUE LED conversion: http://g35driver.com/forums/lighting/39381-stage-4-done-blue-ac-compass-temp-display.html.................................................. ..."NO [U R L], NO [I M G], only 1 line" ........................
Old 02-20-2008, 02:56 AM
I dunno about that. All you need to do is remove the pins on the Brembos to get the pads out.
__________________
DG 6MT Coupe // Brembo // JWT // Borla // 06 Projectors // Eibach-SPC // Hotchkis // Tein Z S-Techs // Z Tokicos // Eclipse Audio // Polarg // Redline // OEM 18s and 19s // AND YES, MY G IS REALLY THAT CLEAN
Old 02-20-2008, 04:15 AM
you guys should check out the rest of the DIY videos.. they stickied them in the sedan section.. I don't know why they didn't sticky them in the coupe section
DIY Video Series
__________________
Old 03-18-2008, 10:49 AM
Be nice if someone had the NON-Brembo video. I enjoyed that but want to see the same in the standard brakes.
__________________
04-G-35 coupe 5AT Desert Platinum. Sunroof, Bose, Heated leather, Premium Wheel and tire package.
Old 03-18-2008, 11:48 AM
Quote:
I'm going to do the rear ones on my sedan pretty soon.. and it's going to be an "official" vid, unlike the brembo one
__________________
Old 03-18-2008, 11:53 AM
Excellent! I assume the coupe non Brems would be the same as the sedan.
__________________
Old 02-17-2009, 03:14 PM
I purchased my G35 about a year ago and changed the brake pads out over the summer.
The instructions leave out one very very important step: Prior to bleeding the brakes, you must heat up the Brembo calipers around the bleeder valve. This will expand the aluminum around the bleeder slightly and allow the bleeder to easily come out.....I didn't do it because my G was only 47,000 mi old and the brakes had never been serviced and figured the bleeders would loosen easily.....boy was I wrong. I didn't even apply much pressure on the wrench but the bleeder valve broke off right above the threads and below the hex. A screw extractor wouldn't work since the material of the bleeder valve remaining in my caliper was too soft. In the process of trying to work the remaining bleeder valve out, I messed up the valve seat area. New Brembo calipers are $1200, and that wasn't an option.
Luckily, I was a designer at Ilmor when this happened and they have a nice machining area with many talented machinists. He rigged the caliper in the vise on a mill and we were able to put in a $5 brake bleeder repair kit from NAPA. It is basically a 1/8"NPT bushing with a bleeder valve seat machinined in the middle. The bushing barely fits on the caliper when drilled to the proper NPT fitting depth, so make sure your machinist has the caliper securely set-up. I'd say to pull this off, he needs to able to tap the hole within +/- 0.5mm concetric to the fluid passage. That will leave you with enough material for the threads to grab onto.
There are other things to do to fix this too, but take longer to fix, involve welding of aluminum, precision machining of goofy angles, and a new $12 (i think) Brembo bleeder which not many people have access to. If I have any more problems with that bleeder, this is the route I'm going to have to take...but I shouldn't since the bushing will never be removed.
The easy way to prevent this chaos is just to heat your calipers.
Old 02-18-2009, 01:59 AM
how do u prevent from burning the paint on the caliper
Old 02-18-2009, 04:42 AM
Sylvan Lake V35's Avatar
Dr. DIY
2003 Infiniti G35
Quote:
Use a heat gun not a torch and heat it up slowly you wont have to boil it.
__________________
Quote:
Originally Posted by Calvin View Post
if you have to run stupid camber and small tires, then your wheels don't fit. good fitment is wheel/tire flush, normal sized tires, normal camber.
Old 02-19-2009, 02:46 PM
According to their website, their general caliper spec says the calipers can handle 410 deg F maximum under braking conditions. Keep in mind this is with all the braking forces on the caliper as well. So the paint should definitely be good up to that point. Really, if you go any higher than that, you'll risk damage to the o-rings as well...A good viton o-ring is pretty much junk after 390's degs F...And I think that's actually the material of o-ring they use to seal the fluid passages.
Like ^ alread posted, using a heat gun would be better than using flame since it would increase temp of the aluminum more uniformly...also you can control temp on a lot of heat guns.
Old 08-17-2009, 06:05 PM
mine were fine without any heat when i did my brembo's last Fall... (?)
  #30
Old 08-20-2009, 05:24 PM
Quote:
It's just a preventative measure to keep it from happening. Only one of my bleeders were frozen, not all of them....but that's how many it takes for a basic job to go from easy to a nightmare. I tell people you must do it, because trust me- you don't want it to happen.
Kinda like if you don't want to get struck by lightning, don't stand in the middle of a field holding an umbrella. If you don't want frozen bleeder vlaves, just put some heat on the caliper and expand the aluminum. It's not hard to do...and may add like 10 minutes to the job.
Tags
bleeder, brake, brakes, brembo, caliper, change, changing, kit, pad, pads, repair, replace, replacing, screw, squeal
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
