MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Brakes & Suspension (DIY)
User Name
Password
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Search this Thread Rate Thread Display Modes
Old 05-04-2008, 01:06 PM
Hotchkis Sway Bars Installed
So I just installed Hotchkis sway bars on my 06 sedan. For the most part the installation was easy and took a bit under 2 hours.
Hotchis' guide is pretty good:
http://www.hotchkis.net/files/instal...ides/22413.pdf
In addition to this guide you'll need:
  • 17mm socket. The manual says the end link nut is a 14mm, but it's really a 17mm.
  • 14mm deep socket. The nuts holding the frame brackets are too deep to reach with a regular socket or a wrench.
  • Pliers to bend back the tab on the end link.
  • Breaker bars!
I set my bars to soft in the front (second hole, 15% stiffer) and medium in the back (middle hole, 125% stiffer). The ride improvement is noticeable -- there's less body roll and a bit less understeer.
Old 05-05-2008, 01:40 AM
so..in order to readjust the settings, do you have to take the tires off everytime? or just jack up the car, unbolt, change holes, re-bolt back up, and un-jack?
__________________
front lip=$300, wheels=$3k, coilovers=700, other mods=$3k+ more....Props from sooooo many strangers = PRICELESS "If i mix shell v-power and techron gasoline together... will i have VTEC?"
Old 05-05-2008, 12:34 PM
You never have to take the wheels off...just jack, unbolt the bar from the end links, and swap the holes.
__________________
2006 G35 Sedan 6MT | Premium Package | Hotchkis Sway Bars | 350z Suspension | Hawk HPS Pads
Old 05-05-2008, 09:42 PM
twin001's Avatar
That's what she said
It's easy to adjust because the end links swivel. I upgraded my end links at the same time
__________________
2006 6MT Coupe | Nav | RAS | PowerLab | Motordyne MREV & XYZ | Hotchkis | UTR | K&N | OSIRIS | Project Mu | Falken | NISMO
Old 05-05-2008, 10:11 PM
you have to bend back the tab on the endlink bolt? really?
cause on the stillin's that tab either goes on the adjacent hole
or the bottom/side of the endlink.
__________________
2004 G35C 6MT Brilliant Silver - Click name for drop down box to see homepage.
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
