Thread Tools | Search this Thread | Rate Thread | Display Modes |
Help with DIY Brake Line replacement
So I decided to DIY my brake replacement on my 05 G35 Sedan. Got new rotors, pads, and SS brake lines. My question is, will I need a special wrench to remove/install the brake lines? If so, do you know the correct size?
Thanks
__________________
05 G35 Sedan 6mt OB, Aero Pkg, Premium Pkg, 18x8 OZ Tribe EVO, 245/45/18 General Exclaim UHP, Stillen Exahust, Unrevised 350z Springs, 20% tint, JDM RHD Battery Cover, Clear Corners |
Technically yes. You should be using a brake line wrench. BUT, I've used a small vise grip type wrench with good success. It had a special notch that just happened to grip the brake line bolt perfect. But normal vice grips will work. I sometimes use these as it's better than using a normal open end (if you don't have a special brake line wrench. although they are cheap). The open end just strips the bolt.
If you don't have a vice grip and have to buy a tool, then go ahead and just buy the brake line wrench from Sears. I believe it's a 12mm or a 10mm.
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks *meow* Quote:
Quote:
Thanks for the reply. the guy at Autozone had no idea for our cars. So I thought I would ask here. A set of 3 wrenches, which covered 6 different sizes, was only $10. So no big deal to get a set.
__________________
The SS lines are easy to put on also. It takes longer to bleed the lines. Chime in after you're done and let me know how you like them. I put on the SS lines also but I upgraded my calipers/rotors at the same time. hard to judge what teh SS lines alone did.
__________________
Quote:
Thanks again. I went with Powerslot rotors and HPS pads. Looking forward to getting them on.
__________________
I'll be installing a set of SS lines on my G pretty soon, I'll make a DIY vid when I put the new lines on. You should be using a crow's foot wrench, like the kind shown in the service manual, otherwise you might risk stripping the brake line nuts.
__________________
Maintenance, modification, and repair services. Email me for info. info@infiniticare.com DIY Video Series: http://g35driver.com/forums/g35-seda...eo-series.html |
Quote:
Don't you mean an flare end wrench.
__________________
http://g35driver.com/forums/repair<a...sorry-56k.html |
Quote:
That's another name for it. FSM calls it "crow's foot."
__________________
The do make flare nut crows feet.
Open end Flare nut end
__________________
Quote:
thanks for clearing that up. that's what I meant ![]()
__________________
hah! No. the storms here in florida last week flooded my garage. only just in last couple days has dried out. But now I am sick, so who knows when it will get done. hopefully this weekend.
__________________
Quote:
I'm doing a video probably this weekend.
__________________
Quote:
Funny you should ask. Erwin (erdog) and I just got done changing his oil and installing a magnefine AT filter and we filmed the filter install so that's coming up. Next we're filming a rear camber kit install (spc brand) and then I'll be filming a clutch fluid flush and an SS brake line install. I'll try to get the vids posted asap.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
