im in the middle of this install now, and found that 2 of the pins were longer than the others. has anyone else ran into this problem? idk what i should do...
gizmo- do you have the front set only, or the front and backs? You should have 4 longer pins, 2 for each front caliper, and 4 shorter pins, 2 for each of the rear calipers (if you have the rears as well).
hey i have a question, when using the two person method i should have someone pump the brakes and hold it while i drain the old fluid and have the mc stayed at full? how do i know when to stop draining the fluid and how will i know when the new fluid replaces the old?
