DIY: Spring Install Only
Rating: Thread Rating: 3 votes, 5.00 average.
  #136
Old 08-12-2012, 01:37 AM
Pinoy_G35driver's Avatar
Originally Posted by G35CDriver
Might be the wheel bearing . Jack the car up and see if you have any play in the wheels. Sorta like a knocking around or thump sound . That could make a sound while driving......
^^ Any play?! what do you mean? and how do i fix that? i think thats it! Its a knockin sound but not loud. I had to let the gas go to hear it.
  #137
Old 08-13-2012, 01:17 AM
https://g35driver.com/forums/brakes-...ml#post6540975
Here's a thread i started. Posted a link to a short video of the noise im hearing. in-cabin, windows up.
  #138
Old 08-17-2012, 01:17 PM
2005Garrett35's Avatar
Hey guys,
I'm having trouble removing "the bolt from the base of the strut that runs through the lower control arm" Mine seems pretty snug. I don't have access to air tools and I have tried liquid penetrant
Any suggestions would be great! Thanks!
  #139
Old 08-17-2012, 02:45 PM
Scrildo's Avatar
Originally Posted by 2005Garrett35
Hey guys,
Long **** breaker bar should do the trick if you can get it in there. If not if there's a harbor freight by you go buy a corded impact wrench.
  #140
Old 08-17-2012, 05:49 PM
trocketsone's Avatar
Hey guys,
Corded impact wrench from harbor freight is what I used for all the bolts. Should come off easy.
  #141
Old 02-12-2013, 03:00 PM
lamoz's Avatar
Just did my fronts.. I did not have time to do the backs because it was a bitch compressing the new springs. I had to use 4 spring compressors (2 trips to the auto parts ) and my impact wrench and even then it was very hard to compress them. I went with Tein S because is what I had on another car.. the drop is very noticeable
I will attempt the rears this coming weekend and hope that it's easier. I will post photos of the the drop and I'm guessing camber kits will be in my future.
  #142
Old 02-12-2013, 04:21 PM
G35CDriver's Avatar
wow, sounds like a long day but glad this write up helped...
The rears are really easy to do.
  #143
Old 02-22-2013, 02:53 PM
lamoz's Avatar
before and after pic. Love the look and the ride is not bad.. Much more solid in the turns
  #144
Old 02-22-2013, 06:38 PM
G35CDriver's Avatar
Looks great. Thanks for the pics.
  #145
Old 04-03-2013, 08:08 PM
CORONAG35's Avatar
Great DIY ,simple and easy.....
  #146
Old 04-03-2013, 09:44 PM
G35CDriver's Avatar
Thanks. I try to help my fellow g drivers..
  #147
Old 04-22-2013, 02:17 PM
Cubes's Avatar
Thanks for this DYI guys...the pictures helped greatly.
I just installed the 350z H-Techs on my '06 6MT last week with a friend and it turned out and she looks great!
I found that the fronts where not difficult at all other than compressing the springs take a LOT of time. Other than that, if you use PB Blaster in the center strut bolt prior to removal and let it sit, its quite easy (mine is not winter driven thus no rust probably helped a lot). Definitely recommend an impact gun for removing some bolts (caliper and top strut bolts)
The backs where for the most part easy other than removing the caliper bolts...due to how small area back there, I couldn't get use my impact gun to remove the bolts and it was a major B!@TCH!!
NOTE:
Make sure that when you are putting the new springs back on the struts and compressing it, that the center bolt its properly sat or it will spin like mad without actually tightening possibly needing a strut replacement.
I didn't know this (or didn't see it in the DYI) and when I was done, the nut would not tighten. I panicked!!
All in all great time with my buddy and felt great to have done it myself.
  #148
Old 04-22-2013, 09:15 PM
G35CDriver's Avatar
Cool cool.
  #149
Old 05-01-2013, 04:02 PM
BSg356mt's Avatar
I'm going to be replacing my shocks soon and stumbled on your post but I don't see any pictures. I have replaced my springs about 5 years ago to some 350z H-techs and wanted to freshen up on the procedure but the pictures are gone. =(
EDIT: I can see them by clicking on the images one by one.
  #150
Old 05-01-2013, 10:10 PM
G35CDriver's Avatar
Huh......I will try to fix this issue.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: DIY: Spring Install Only
