| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
End Links
Can you clarify why it's necessary to remove the bolt for the end links from the lower control arm (sway bar links)? Does it put pressure on the lower control arm that needs to be eased so the arm drops down to remove the strut?
__________________
Security Engineer by day, drifting the G by night |
Well the bolt needs to be removed because the lower control arm can not be shifted down enough to remove the strut with it in place. Hope that helps.
Quote:
This is what I thought! I noticed some people do not remove the upper bolts from the upper control arm (a-arm if you will), while others do. It seems that you can remove the strut through the bottom without bothering with the removing the upper control bolts. Can you comment on this?
__________________
It's not necessary to remove the upper control arm, but removing it certainly helps get the strut out. It's only 2 bolts per side, and if you don't it's just going to hang down in the way, making it a real PITA to get the strut both out and back in. You've got to hold the arm up somehow, so why not just take out 2 bolts.
__________________
2005 Diamond Graphite G35x |OEM Z-Tube|K&N|HR Z Y|MD 5/16ths Cu ISO|Rev-up Airbox|SBD 10 Wire|Bump Clears-Blinker Mod|Coupe 18's|RE760 Sports| |
Quote:
So how about the rear springs?
i assume you jack it up and compress the spring? and that's it? i haven't taken a long enough look underneath to make a good guess edit: nvm i read a different thread, looks good i'm getting my prokits today. i guess they're going on next week.
__________________
2004 Coupe 6MT |Brembos|Greddy Evo2|JWT Pop Charger|OEM ZTube|Eibach Pro Kits| |
the reason why I placed the jack on the rear is to take the load off the bolt so as it is removed it does not crossthread itself because the bolt pretty much has to be turned the whole way out.
Quote:
You may have to get a jack under the lower control arm, too, to compress the spring/strut assembly enough to disassemble/assemble the lower strut bolt and the sway bar links (it really helps to align them so they go on/come off more easily). Trust me, you do have to undo those links. When we did mine, we undid the single upper a-arm bolt rather than let the whole thing down. I'm thinking your way may have been easier as it took a little wiggling to get that strut outta there. We're doing another car Thursday night, maybe we'll try that!
__________________
2003 Emerald Mist/Graphite || Z/Coupe springs||Rays 19s||Stillen CAI w/CF tube || Skunk2 plenum spacer || 350z-Middy || Stillen sways || Philips/PIAA 6000K || nismo shiny things|| AMSOIL syn fluids |
Quote:
to those of you who removed your factory springs..can you tell me if the red mark on the spring is supposed to go towards the bottom or the top when installed from factory? I'm asking b/c when I reinstalled mines, I might have put them in the wrong direction.
__________________
Brilliant Silver G35c 6MT |
i believe that the spring will only seat itself one way correctly in the rear with the markings on the bottom side.
__________________
The Perfect Sleeper |
how about tanabe springs
I don't know about the Tanabe Springs but they sould be marked, most manufactures do mark their springs...
__________________
I was wondering, How much of a drop would it take for a person to end up NEEDING camber kits? 2" drop or more?
#30
I believe that once you go past the 1.5" mark that it starts to throw off the camber. My setup has changed a bit since this was first posted but after these springs had settled i was somewhere around 2 1/8" and could see wear to the inside of my tires. Sat like this //---\\
__________________
| Tags |
| 350z, coil, compressor, correctly, coupe, diy, front, g35, hr, install, remove, rubber, seated, spring, springs |
| Thread Tools | |
| Display Modes | Rate This Thread |
