MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Technical (Do It Yourself) > Brakes & Suspension (DIY)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
  #31
Old 11-07-2009, 12:05 PM
BuckeyeInMI's Avatar
OEM Mod Squad
2005 Infiniti G35
Quote:
Originally Posted by Sammo115 View Post
I was wondering, How much of a drop would it take for a person to end up NEEDING camber kits? 2" drop or more?
Quote:
Originally Posted by G35CDriver View Post
I believe that once you go past the 1.5" mark that it starts to throw off the camber. My setup has changed a bit since this was first posted but after these springs had settled i was somewhere around 2 1/8" and could see wear to the inside of my tires. Sat like this //---\\
The consensus here is that it's probably closer to 1", not 1.5". If you're doing a 1" drop, wait until you completely settle (a few weeks), and then see if you need a kit. If you're doing more than 1", then you might as well just get the kit because you're going to need it.
__________________
2005 Diamond Graphite G35x |OEM Z-Tube|K&N|HR Z Y|MD 5/16ths Cu ISO|Rev-up Airbox|SBD 10 Wire|Bump Clears-Blinker Mod|Coupe 18's|RE760 Sports|
Tags
350z, coil, compressor, correctly, coupe, diy, front, g35, hr, install, remove, rubber, seated, spring, springs
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
