| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
#106
Quote:
Eddie
__________________
Site: www.thmotorsports.com Email/Paypal: sales@thmotorsports.com AIM: THMotorsportscom Phone: 1-800-959-0145 Wholesale Line: 1-800-THM-8180 |
#107
Quote:
I assumed the new camber kits come with the revised brackets. The new bracket is actually bolted into the head of another bolt. But for those kits with the L Brackets, I'm sure that would be helpful. |
#108
721261
That's the repair kit that SPC sent me. This fixed the ABS sensor gap problem that I had which screwed up my VDC and ABS. From what I understand, though, the new SPC camber kits have the new brackets already. |
#109
Quote:
so I talked to Doug @ spc and he told me that since the spring bucket on a RAS car directly attaches to a steering component, you cannot drill to it because: 1 - it's not aluminum 2- the steering adjusts the toe while driving so you have to keep the stock bolts and max them out to a setting that allows for the most positive camber. Now, I'm kind of stuck with having only some positive camber and I will have to continue to run more negative than specs because of this issue. Alex
__________________
06 coupe 5at / KN filter / 20'' Axis Penta / Michelin Pilot A+S / EBC Red Stuff |
#110
Quote:
Quote:
![]() Quote:
2 - Think you got it a little twisted around there. Max the 'camber' eccentrics to positive, then adjust 'camber' with the SPC 'camber' arms. Toe is only adjustable with the 'toe' eccentric plate bolts in original factory location (the mid-link), whether still with oem or more aggressive SPC ones. RAS only activates in hard turns, otherwise it stays neutral and holds your toe spec settings as if not even there like non-RAS G's. G/L
__________________
06 DG 6mt|Aero|RAS|Mods|Revup VQ replacement. |
| Tags |
| 350z, adjustment, arm, arms, camber, coupe, degree, fix, front, g35, infiniti, kit, premature, spacer, spacers, spc, thmotorsports, tire, wear |
| Thread Tools | |
| Display Modes | Rate This Thread |
