| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
Thread Tools | Rate Thread | Display Modes |
![]() We have been a long believer, stocker, and user of SPC products and see that many of you have questions. I know there is a sticky of a Poll, but we would like to see if a mod could make this a sticky in terms of answering any questions you guys have regarding the camber kits. Post up any question you have regarding the SPC Camber kit front/rear etc. If we do not know the answer the ASE master tech's at SPC can help us out to help you out. Thanks, Eddie THM Sales Manager
__________________
Site: www.thmotorsports.com Email/Paypal: sales@thmotorsports.com AIM: THMotorsportscom Phone: 1-800-959-0145 Wholesale Line: 1-800-THM-8180 Last edited by THMotorsports; 09-24-2008 at 05:09 PM. |
Quote:
__________________
SDGz
Recently I received a letter from SPC along with 2 washers. In the letter it states...
"Under extreme conditions the nut on the ball joint stud could pull through the spindle causing a separation of the upper control arm from the spindle and a sudden loss of control. If the kit in question has been installed reusing the OE flanged lock not no further action is required." Is it possible to do it yourself and avoid going to a shop? SPC said they would reimburse $25 for shop repairs but if it's a DIY than I would rather do that. Plus I havent checked yet but I hope the shop reused the OE flanged lock.
__________________
Black on Black 6MT Coupe | Rims: VS-XX | Speakers: JL's
Quote:
On another note, I know others have had problems but my SPC arms perform perfectly, no knocking, and I'm dropped 1.25 inches in the front. Proper installation with the correct spring rates and damping makes a big difference.
__________________
'06 6MT Coupe: Motordyne / Stillen / Borla / Tein / Tokico / Rogue Engineering / SPC / Nismo / Falken / Megan Racing |
hi i really need to get a camber kit for my front tires. im currently lowered on tanabe df springs. what do you got for sale... oh and i drive a 2005 g35 coupe.... thanks! please PM
Quote:
Here is the link: http://thmotorsports.com/spcperforma...0/i-68863.aspx
__________________
Site: www.thmotorsports.com Email/Paypal: sales@thmotorsports.com AIM: THMotorsportscom Phone: 1-800-959-0145 Wholesale Line: 1-800-THM-8180 |
On another thread I heard something about spacers. I'm not sure what this is about and why spacers would be needed with these kits.
the spacers are actually built for more range of camber. As well, putting the spacers on puts the sensors back in line perfectly so you dont get a the VCD light or ABS light. Many have done without spacers, and then just got an alignment which in turn, stopped the problem of the lights going on.
Eddie
__________________
Stickied.
I have the SPC arms and and still running with negative 3 camber in the front. I have been skeptical of isntalling the spacers, even with my "revised" kit. Without installing the spacers, the arms (alone) allow for only ~1 degree of positive adjustment. The spacers will add a static positive 2 degrees of camber. I will most likely be swapping them out for SPL arms when I have the time/funds. |
Quote:
Edward
__________________
I just picked up the rear kit for an 06 coupe dropped on 350Z s-techs.
Installing tomorrow and I have an appointment at pleasanton infiniti on thursday to get it aligned. My question is: is the dealer the right place to go to get it aligned? I think they will probably figure out the camber arm adjustment but are they going to have a clue about the toe bolt? I can try to tell them ahead of time but they won't let you back there when they do it and I really don't want to pay $140 for a 10 minute on the rack toe-n-go. |
thanks again for your help today eddie!
__________________
'05 IP 5AT Coupe | Rare JDM | Stage 4 Performance | CarDomain |
i have a spc front camber kit. its been installed for about a month now and my abs,slip, and vdc light is on. i tryed bending the sensor bracked very gently but i t didnt do anything to help. any ideas? thanks so much
__________________
More stock than your moms car! |
Quote:
2. Do you have the spacers on? Eddie
__________________
| Tags |
| 350z, adjustment, arm, arms, camber, coupe, degree, fix, front, g35, infiniti, kit, premature, spacer, spacers, spc, thmotorsports, tire, wear |
| Thread Tools | |
| Display Modes | Rate This Thread |
