MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Brakes, Suspension, Wheels & Tires
User Name
Password
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Rate Thread Display Modes
Old 04-14-2009, 03:26 PM
highway vibration
new wheels and tires didn't fix the vibration on my 06 G35. The dealer is recommending they tighten or replace the steering rack (at their expense) any thoughts?
Old 04-14-2009, 03:45 PM
jfizz313's Avatar
let them i haven't experienced anything like this so idk.
__________________
OB G35 coupe
Old 04-14-2009, 05:37 PM
goodmank's Avatar
2006 Infiniti G35
I get the same vibration from 65 to 80 and I have an 06 coupe. Let me know if the steering rack helps. I kept thinking it was the alignment, but it still does it.
__________________
BO 06 G35c 5AT ~ See garage for mods ~
Old 04-14-2009, 05:44 PM
I've had two sets of tires put on, then they tried a new set of wheels and tires off an '09 G along with an alignment. I'm convinced the vibration has nothing to do with wheels and tires. I'll know if the steering rack fix is the issue in a couple of days.
Old 04-14-2009, 05:48 PM
goodmank's Avatar
2006 Infiniti G35
Well, if it turns out that it is not the steering rack, you might want to check the axles b/c that is what was causing the vibration on my wife's 03 honda accord.
__________________
Old 04-15-2009, 05:58 PM
Use a vibration analyser to view the frequency of the vibrations this will tell you the diameter of the culprit. A 26" tire at a speed has a certain frequency [and harmonics] of vibration. Simple college physics.
You must use software and a frequency analyser that can accurately measure 10HZ to 100 HZ.................most vibrations are 10>30 Hz and in audible by human ears but easy to see on acoustic FFT anaylser.
EVA or Vetronix [now Bosch] vibration analyzer
http://www.boschdiagnostics.com/TEST.../Analyzer.aspx
http://www.ymec.com/hp/signal2/car1.htm
__________________
http://www.t3auto.com/
Old 04-23-2009, 02:17 AM
goodmank's Avatar
2006 Infiniti G35
Just wondering if you ever determined the cause...
I know the techs at the only Infiniti stealership near me don't have either of the instruments above...and they are a ROYAL pain in the *** to deal with...
I am def pos it is not the tires, wheels, or alignment on mine either; however, I am beginning to get the rear axle click and if the axle is loose, that may be the culprit
__________________
Old 04-23-2009, 04:52 PM
Call the Lexus dealers many of them have diagnostic equipment.
__________________
Old 04-23-2009, 08:28 PM
turned out to be the drive shaft. They replaced it and all seems o.k.
Old 04-28-2009, 07:28 PM
goodmank's Avatar
2006 Infiniti G35
Was it the pass or driver side or both?
That's what happened to my wife's 03 V6 accord coupe. Turned out the inner drive shafts are made with really cheap parts and they seem to fail pretty frequently so I ended up getting brand new gator axles.
__________________
Old 05-11-2009, 06:37 PM
Wow seriously it was the driveshaft.. Thats what I think is wrong with my car because you can definitely feel it in the shift knob around 60mph deceleration, it feels like the driveshaft is vibrating really bad, I checked my wheel bearings and they are most definitely okay, it doesnt move whatsoever.. my god I have aftermarket warranty will definitely not cover that im sure.. Is that consider as wear and tear or what?? How many miles on your G
__________________
03' Coupe 6MT, Diamond Graphite on Black Leather, 5% Tint, 20" Axis Pentas on Falken 452s, JWT Clutch Flywheel Combo, Motordyne 2.5" Exhaust & 5/16 Spacer, Stillen Air box + Z-Tube on the way
Old 05-11-2009, 08:12 PM
yeah, couldn't believe it myself. The "U" joint was binding up so they replaced the whole shaft. Covered under warranty. The car has about 50k miles.
Old 05-11-2009, 08:25 PM
Well I hope it is.. I got aftermarket warranty.. hope its covered
__________________
Old 05-12-2009, 12:37 PM
Important to exercise u-joints [periodically with a hammer] so that they do not bind up, become notchy and do their job.
Something known to happen to driveshaft since the 1960's. Some last 50k some 150k.
Every wonder why each medium sized city has at least one driveline shop that specializes in rebuilding and rebalancing abused driveshafts.
People who grew up on FWD have no concept of RWD/AWD problems and solutions.
__________________
Old 05-13-2009, 09:22 PM
1 piece driveshafts hurt my feelings..
__________________
Tags
65, accord, coupe, driveline, driveshaft, fixing, g35, g35driver, highway, honda, knob, miles, rack, shift, steering, vibration
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
