MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Brakes, Suspension, Wheels & Tires > Brakes & Suspension
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 08-12-2006, 01:43 AM
^ +1
__________________
-Sean
Old 08-12-2006, 01:45 AM
Thanks for the reply...Just one more question...If we have these bags on we can't drive the car aggressive anymore correct?
__________________
Socal's Summertime's BBQ Bash!!! Closed!
Old 08-12-2006, 02:06 AM
How do we know what height to set it at? I know when you flip a switch it deflates all the way and inflates all the way...what about between? Let just say I want it at a certain rolling height...how would I know?\
Also, why would I chose this over air cylinders?
Old 08-12-2006, 06:01 PM
Quote:
Originally Posted by Clean G 4D
How is the ride quality from the bags versus a normal or sport spring/coilover setup?
Its a nice mixture between both stock and sport/coilover. Typically most people say that is the same as it was before. With the air bags it will go from a nice and soft over small bumps to stiff over large ones. The air spring acts as a dynamic progressive spring.
Old 08-12-2006, 06:03 PM
Quote:
Of course you can. We have designed the system to both look good and still performe excellent. You will not suffer performance losses with changing from an coil spring to an air spring.
Old 08-12-2006, 06:09 PM
Typically you can just say hold the switch down to lift all the way up and tap it down twice for your height or what ever it takes to get to your height.
Also you can add on a dakota digital controller unit to where when you start the car it will set it to your desired height. Or they also have an auto ride controller that will have a "low, med and high" buttons for what ever you set those to.
The main advantage to running our bag system instead of an air cylinder is performance and life. With air cylinders your performance will suffer because you are removing the shocks and placing air cylinders in place of them. With the bags your just removing the coils and keeping the shocks all the way around.
Also with an air cylinder there is a moving seal inside that will have alot shorter of life then an air bag that is compressing and extending.
Some advantages that an air cylinder does have is that you can fit it into alot smaller of space. (i.e. honda's) where an air bag will just not fit properly. Also you can reverse pressurize an air cylinder to pull the wheel up off the ground.
Typically an air cylinder is the 2nd choice when an air bag will not fit or you want to "3 wheel".
Old 08-12-2006, 06:56 PM
would u b able to take turns fast and still drive fast? b/c when i get on the highway i do like 120 or more. i dont want to pop a bag and i'll b a$$ out.
Old 08-13-2006, 04:32 AM
hey guys, I found a member that has this system -jdbinspired.
Here is his thread...
http://www.my350z.com/forum/showthread.php?t=208587
Here is the thread about this setup over on my350z
http://www.my350z.com/forum/showthread.php?t=209619
Old 08-13-2006, 11:35 AM
Send a message via AIM to vipv35
do there have to be any modifications to the fenderwell to tuck the wheels?
Old 08-13-2006, 01:19 PM
Isn't here a possibility of popping a bag? Cylinders you can't pop right unless you make a hole in a metal cylinder right?
Old 08-14-2006, 01:33 PM
Quote:
Of course i wouldn't "recommend" ever going faster then the speed limit no matter what your suspension is.
However on your local racing track where you are performing those speeds there will be reduction in handing over your current suspension.
Personally i have tested them out over 100 mph and then handling was increadable.
Old 08-14-2006, 01:34 PM
Quote:
It depends on the offset of your wheels. Now when you drop the car the wheels will camber in.
Old 08-14-2006, 01:41 PM
of course there is a possibility to pop the bag. The chances of it are very VERY slim unless you install the system wrong or abuse it. The ways to pop the bag is for something to rub against it or over pressure trying to hop the car off the ground.
There is a few different ways to pop a cylinder. You can have something rubbing against it. Driving the vehicle too high and have them max out like a slide hammer and rip them apart. but the most common way is to have the internal seal get damaged and air blow right through it. Most common on the seals is from debits or from friction from moving up and down they will wear out.
Old 08-14-2006, 01:47 PM
Meatshake Enterprise
Send a message via AIM to sen_jen
aside from price, why should folks consider these over Bold World/Airrunner?
__________________
MEAT HER MUFFIN. RIGHT ON JESUS
  #30
Old 08-14-2006, 02:30 PM
The Dakota digital air/height controller is a nice set-up to include with any air-suspension system. Has 3 presets buttons for low/med/high and full dump. I have the optional wire-less remote feature with my set-up. If you have a bodykit, air-suspension are great for looks and it may prevent bodykit damage, simply raise it when driving over a bump or a steep driveways. Best part, car looks cool fully dumped when parked.
__________________
04.5 OB 5AT, Prem/Nav | SFR/SSR 60-1 BB TwinTurbo, 417rwhp@7.5psi | Stock VQ, SFR rebuilt tranny | Autometer Nexus | Innovate a/f | 20" DPE R07 v.S | KenStyle bodykit w/Ings+1 Fenders | Seibon TS CF hood | AirRunner air-ride Suspension/Dakota digital | HKS high-power TI | Eclipse avn5435/ CDT es643.
Tags
2006, 350z, air, aluminum, bag, bottom, g35, install, kits, photos, plate, ride, runner, rust, suspension, tanks, uas, universal
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
