MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Brakes, Suspension, Wheels & Tires > Brakes & Suspension
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 08-10-2006, 09:24 PM
Air Suspension Questions
Here at Universal Air Suspension we manufacture an air bags that slide over existing factory or aftermarket struts/coilovers to retain the cars handling.
I would like to open this thread up to any question/concerns anyone has about Air Suspension.
Old 08-10-2006, 09:29 PM
Send a message via AIM to silvernole12
Do you have a picture of the kit on a G/Z? Explain more how the system works?
Old 08-10-2006, 09:33 PM
Send a message via MSN to k_hojnacki
nice web site and the G looks good! For those that want a direct link:
http://www.universalairsuspension.co...?sid=61&cid=28
Old 08-10-2006, 09:36 PM
Thank you.
You can also view the Z at http://www.universalairsuspension.co...p?sid=9&cid=11
On our website on the front page there is a little video that we did with history channel on the Chrysler 300 that will explain everything on how the air system works.
The only main difference between the 300 and the G/Z is that the front you do not have to cut anything on the strut. The lower spring plate pops off (stock strut) and the new plate will go inplace of it.
Old 08-10-2006, 09:38 PM
Lets make this easy...
Old 08-10-2006, 09:42 PM
nice set up
what are the prices
just to let you know infiniti ends with an I not a Y
Old 08-10-2006, 11:56 PM
So it uses the existing springs and struts but just raises the car when needed?
I am assuming that when you drop the car via a switch, it will lower to the whatever you have your spring height set at?
And how difficult is the install?
Does with work with ANY aftermarket spring/strut setup?
__________________
2006 E46 M3 Competition Pkg 6MT - SG/BLK
Old 08-11-2006, 12:11 AM
How does this affect alignment and what's the warranty on the bags? Have you ever had a bag collapse?
__________________
Socal's Summertime's BBQ Bash!!! Closed!
Old 08-11-2006, 12:22 AM
Nice looking drop.
__________________
04.5 OB 5AT, Prem/Nav | SFR/SSR 60-1 BB TwinTurbo, 417rwhp@7.5psi | Stock VQ, SFR rebuilt tranny | Autometer Nexus | Innovate a/f | 20" DPE R07 v.S | KenStyle bodykit w/Ings+1 Fenders | Seibon TS CF hood | AirRunner air-ride Suspension/Dakota digital | HKS high-power TI | Eclipse avn5435/ CDT es643.
Old 08-11-2006, 07:06 AM
From the video it doesn't use the springs at all which I thought too when they said coilovers at first. All it reuses is the struts and shocks. The bags replace the spring.
Old 08-11-2006, 12:25 PM
THE BATMOBILE
looks pretty sick
__________________
---> My 2003 G35 OB G35 Coupe <---
Volk GT7's DB|Full Ings Body Kit|Bat's and Danno's Overlays|PIAA's Everywhere|Black Injen CAI|Pro-1 Exhaust|UT Y-Pipe|Crawford Plenum|UR Pulleys|Gordgee Grounding Wires|Gialla Grille|Eyelids|Limo Tint|Samco Hoses|Momo Shifter|
Old 08-11-2006, 01:14 PM
Quote:
Originally Posted by 2004v35
nice set up
what are the prices
The discount for the Forum is 2150 shipped to the door in U.S.
Lol, i cant believe that... I have had the web guy fix it....
Old 08-11-2006, 01:16 PM
The air system Replaces the springs on the car. The bags will be the primary suspension on the vehicle.
Bolt in application.
You can adjust it anywhere between the lifted and lowered pictures.
It will work on any strut that is 2.14 or smaller on the OD of the shock body.
Old 08-11-2006, 01:17 PM
Quote:
When ever you lift or lower a car it will change the alignment. What you do is set your ride height that you like then have the vehicle aligned at that height. That way you go back to that height it will be the correct alignment.
We give a 3 year, 36,000 mile warranty on our bags. We have road tested at over 100k miles and cycle tested at over a million cycles.
The main reason why a bag would blow out would be from installation issues. (not on G's, on other cars) May issue is when someone throws a bag in without setting up the brackets correct. Thats why we have designed the brackets already. Its litterly as easy as pulling off the spring and putting the bag inplace of it.
The 2nd reason is from over pressure. With our kit it will not even be close to the "burst pressure" of the bags. You would have to run very high pressure with compressed gas (i.e. Nitrogen) inorder to damage from pressure (Trying to hop the car)
Old 08-11-2006, 09:25 PM
How is the ride quality from the bags versus a normal or sport spring/coilover setup?
Tags
2006, 350z, air, aluminum, bag, bottom, g35, install, kits, photos, plate, ride, runner, rust, suspension, tanks, uas, universal
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
