My alignment spcs....
How do my alignment specs look to you guys. I was told my Firestone that the front camber or caster is not adjustable per Nissan. Is that true? I dropped the car on 350Z springs.
Let me know
Front Left
Camber -1.1
Caster 8.1
Toe 0.02
Front Right
Camber -1.4
Caster 8.1
Toe 0.03
Rear Left
Camber -1.2
Toe 0.09
Rear Right
Camber -1.1
Toe 0.10
I bought the lifetime alignment warranty so if something needs to be changed let me know and I will go back and have them make the adjustments.
Let me know
Front Left
Camber -1.1
Caster 8.1
Toe 0.02
Front Right
Camber -1.4
Caster 8.1
Toe 0.03
Rear Left
Camber -1.2
Toe 0.09
Rear Right
Camber -1.1
Toe 0.10
on
Lifetime alignments sound like firestone?... I didn't know they did a 4 wheel alignment you will need a 4 wheel alignment. Now are these where your specs are now or what they adjusted them to? I don't have my spec sheet in front of me but others will chime in on this about the specs but if they will not do a 4 wheel take your business someplace else.
All Firestone's do a 4 wheel alignment, unless the vehicle does not have rear adjustments, the price doesnt change either way.
They are correct, there is no front camber/caster adjustments from the factory on our cars.
Those specs are pretty much spot on, they did you good. Just make sure you take it back every 6 months, 6k miles to have it checked.
-GP-
-GP-
Question for for the others. I'll be dropping my car next weekend on Z springs up front & coupe springs in the rear. When they do the alignment, will they automatically know what specs to use for it? (i.e. do they have to use the Z/Coupe specs, since those are the springs I'll be using, or do they use the sedan specs.)? I'm confused now (myg35x's post w/ the Coupe specs threw me off here).
Thanks
Thanks
yes sir they will. I have 4 G coupes here in SanDiego that all bought liftime alignment policies at the Firestone i work at. There is also a couple slammed civics that we do as well. As long as they have a competent tech that wont rip off your sideskirts when pulling up the ramp then it's no problem.
-GP-
-GP-
