Lowest Slammed G35? Post pictures & suspension..
#169
^ If your tires aren't OEM sized (225/40/19 & 245/40/19), then I recommend going with 20mm front and 25mm rear spacers. Make sure to get the hubcentric rings.
I'm dropped sort of low (not as low as you) with stock sized tires, and the fronts rub when I turn the wheel enough when going into a driveway.
#172
#174
#176
#179
on
Here's a few old pics of my ride that I found...still had more room to lower the coilovers but I was scraping enough as it was....had to replace my y pipe and cats, plus some hangers got messed up pushing my exhaust back over an inch
Here's one with the Karookie bumper on...
WOW the bumper looks like its literaly touchin the ground....so f***en low hahah
