Sign in using an external account
Thread Tools | Search this Thread | Rate Thread | Display Modes |
Anyone tried R1 Concepts OEM rotors?
__________________
2011 Lexus CT200h Premium (Obsidian w/ Black Nuluxe interior) Always Maintained by Detailed Image |
I do not have them, but I was considering them for a little while. After reading reviews of what's been going on with their rotors, I decided against them and started looking elsewhere.
__________________
~~~~~~~~~~If you're near Cincinnati and have 2004 Coupe seats for sale, PM ME!~~~~~~~~~~ |
Don't have any experience with them but have known a number of people who went with Racing Brake and had good results.
__________________
ONE FUN SEDAN!! MY CAR (LINK) Detailed Image | Greddy Twins & Motor by UMS Tuning = 649whp/651wtq | Rotora | IForged | 1-off Dual 3", Dual Muffler Exhaust by Nichols AutoFab | SPARCO | |
dont get me started!
search my threads for a good review and tons of responses. short version...buy from www.ocautosports.com instead |
^ i dont want to bash them or anything Shawn but i bought from OCAUTOSPORTS.com... the rotors were ok but the pads were just crap. i had no stopping power and they squealed like no other. when i had pulled the pads off they had glazed over.... If you do decide to go with them, specify the pads you want!
__________________
04 SGM Sedan, 5AT, JWT, V.1 Crawford Plenum, JDM Clear Corners, JDM Tails, 06 Brakes, SxExCx, Z-Wheels, Tanabe, Basics, Poly Nismo,Auto Explosion Custom Body work, BAUS Auto |
Quote:
__________________
i just recently installed r1 rotors and they are fine so far. I painted the slots and holes black and im not getting too much rust problems like others too. Braking is good and everything is good
__________________
Impul | Fast Intentions | SPC | Volk | Motordyne | K&N | Richie SB| Tein | Kuruma | Toyo | JL Audio |
Quote:
I have those Rotors and R1 is the distruibitor they are actualy made by CENTRIC the same company that manufacturs rotors for STOP TECH.
I have NO complaints I painted the centers black 3 layers to avoid rusting.
__________________
NISMO ~ BBS RGR ~ BREMBO ~PROJECT MU ~ STILLEN ~ AAM ~ TEIN BASIC ~G37 Projector Retrofit |
I haveR-1 premium drilled/slotted, painted surface with high temp rotor paint; no problems and good stopping power.
__________________
A fine is a tax for doing wrong. A tax is a fine for doing well. |
Thr R1 rotors are great. I am using them on both of my cars. I haven't had any customer service issues either. In fact, they called me to let me know the pads I ordered were on back order and wanted my input on what to do.
I agree that the Centric Posi-Quiet pads lack good braking feel. I am replacing them ASAP.
__________________
Florida G Club - '03.5 Caribbean Blue 5at Sedan & 06 Autumn Copper FX35 |
I just installed mine. The rotors look good. But the pads on the other hand looks like a cheap piece of chit.
__________________
Do not believe in anything simply because it is spoken and rumored by many. |
Well I bit the bullet and ordered the R1 Concepts cross drilled and slotted rotors, both front and rear. I received them a few days ago and installed just the front ones today (there's no space for me to remove the calipers in the rears, I might have to go to a shop to get them done).
In any case, the rotors look really good compared to my stock worn-out ones (the front ones measured at 20 mm thickness so they needed to be replaced bad). Performance wise, the braking difference is night and day; it's more grabby and similar to how it's felt when a G rolls out from the showroom. I love it overall, I'll post up some pics once I get the car washed up. Quick question: Do brake pads generally wear out faster with cross drilled and/or slotted rotors than the blank OEM rotors (kinda similar to the effect of a cheese grater)? Also, when I apply the brakes semi-hard from 30-40 mph and slow down to around 10 mph, I feel a slight shudder on the brake pedal. Is this normal for new cross drilled and slotted rotors, and will this shudder feeling go away once the new rotors break in after a while?
__________________
Quote:
You will feel a slight shudder when you get new rotors b/c they need to match surfaces with the pads. Make sure you do the proper bed-in procedure and you should be okay to go. Just to give everyone a heads up, I was part of the intial group buy on the R1concepts rotors. There was a huge issue with the rusting problem with the rotors. When it came time to get rotors again (a few weeks ago), I contacted Sam from R1concepts and asked him if he could get me the premium rotors and zinc coat the ENTIRE rotor. He was able to send me the rotors as I requested and they are much better in appearance. It just got done raining here and I have NO RUST on any part of the rotor. Essentially, any part that was zinc coated was wiped away by the brake pad. So far so good. If you are interested in picking up these rotors, contact Sam from R1concepts and ask for the same setup. I will post pictures of the rotors when I get a chance. |
Quote:
| Tags |
| bed, blanks, break, centric, concepts, posi, procedure, quiet, r1, r1concepts, rate, review, rotor, rotors, sam |
| Display Modes | Rate This Thread |
