Thread Tools | Search this Thread | Rate Thread | Display Modes |
need g35 help please regarding brakes!!!!
i live in the uk and have just purchased a skyline 350gt which was imported from japan to the uk. only thing is there is nowhere to get your basic parts i.e brake pads, we have plenty of 350z,s in the uk , so i was wondering if any of you knew if the standard nissan 350z brake pads will fit my 350gt, my car does not have the brembo brakes fitted, also could you tell me what parts the 350z uses that also are on the 35ogt thanks
what year, model is your car? 6MT or 5AT? you can look on www.buybrakes.com and see what part numbers are the same between the Z and G35, and you can do the same on www.stillen.com. check the applications tab on the stillen site and it will show what car that perticular fits on. and most all the 350z parts are the same as the G35.
__________________
'06 OB Coupe 6MT / Stillen Z-Tube / Stillen CAI / |
in any case, it wouldnt be too complicated to switch over to 350Z suspension and brake components as most through out the years are similar enough.
Between the two (in the USA), standard brake sizes have changed throughout the years, but suspension components like A-arms etc have remained the same and are exhangeable. Provide us more info on your exact model and year and we can help out more specifically.
__________________
I hate being a passenger! 2004 DG coupe 6MT Sport Premium l Cobb Sways, Circuit Sports FSTB, Nismo Z-pipe with OEM airbox with Purolater Drop-in...always buying more parts. |
Isn't this the same thing as the Z? Try here
http://www.350z-uk.com/forums/portal.php You have the equivalent of either the Z or G. Both of which are sold in the UK and therefore parts availability should be no problem
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks *meow* Quote:
Quote:
The brake pads for the 04 Z will fit the 04 G also. (non-brembo).
__________________
Quote:
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
