Thread Tools | Search this Thread | Rate Thread | Display Modes |
Upgrade Suspension
Hey guys I did search for this info 1st but I can't seem to find everything I need to know...
Basically, I want to lower my g coupe with springs that will lower about 1-1.5'' to make her stiffer, look better and improve cornering/handling, yet still able to drive everyday... I wanna get rid of the wheel gap, but I don't want the back to sag and look lower than the front... Also, what all should I get when doing springs... new struts/shocks, camber/toe adjusters... I'm not really sure what the toe is... all help is appreciated... |
Most, if not all, of the answers to your questions can be found here:
G35/350Z aftermarket coilover, springs and shocks spec's w/updates
__________________
05 BS sedan/5 AT/Skunk 2 spacer/Z-tube/Amsoil Nano/modified stock air box/R1 Premium drilled/slotted rotors/'07 Z springs waiting to go on |
I was under the impression coil-overs for the G is not worth it because:
-they already sit low -not worth the price -too stiff for daily driving I'm leaning towards Eibach springs (1.1'' F/1'' R drop) & Tokico D-spec shocks... Will camber arms be needed with this combo to keep alignment? Anything else recommended? |
350evo,spc/eibach, spl are good camber kits. im lowered 1.3 and need front and rear camber/toe kits to get back into spec
__________________
04 BS G35c 6MT:Swift:Tokico:Project Mu:350EVO:SPC:Tint:JDM Clears:K&N:Z-Tube:MotorDyne:Nismo |
i have swift sport springs for the 350z....its not to low at all, i have about a 1.5 finger gap on all four sides. i have them mated with tokico d-specs set on 2.5 turns from full stiff. rides smooth and handles better than stock...
__________________
Quote:
If you can afford coilovers, they are worth getting. Some are better than others for the money. The G isn't already too low or else you woulsn't want to lower it. Some coilovers are worth the price. "Too stiff" is subjective, but I would think that most people that have reasonably speced coilovers won't find them too stiff for street use. I have BC Racing coilovers on my daily driver. I find the ride comfortable.
__________________
Sean Florida G Club '03.5 Caribbean Blue 5at Sedan w/ a few mods, '04 Laser Red 6mt Coupe slowly being demodded |
Yeah i was just trying to decide if coil-overs are the better way to go... I just don't want it to be too much stiffer than stock, but definitely somewhat stiffer... I'm just afraid I'll get the coil-overs and it'll be too stiff... If I get the springs, d-spec shocks & camber kit its about the same price as coil-overs.. At least the megan racing ones are $900...
__________________
2004 Black 6MT coupe |
Yeah I think I'm just gonna do the eibach pro springs & d-spec shocks... Do you think it will be necessary for the camber kit with this set up, since it'll only be lowered approx 1''... An alignment might be able to bring it back close to stock... What is the most negative camber I can go with even tire wear?
__________________
A lot of people get uneven tire wear even on the stock suspension. I needed camber kits on my sedan to keep from wearing out the insides of the tires first.
__________________
Probably not, but every car is different.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
