MyG37.com | G35Driver.com | My350Z.com | ZDriver.com
Show Your Support Become A Premier Member
Go Back   G35Driver > Tech Area - V35 > Brakes, Suspension, Wheels & Tires > Brakes & Suspension
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Welcome to G35Driver.com!
Welcome to G35Driver.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today!
Thread Tools Rate Thread Display Modes
Old 01-11-2009, 03:51 AM
Send a message via MSN to Jining
So I had some time today at work and checked all the nissan tsb's (i work at nissan) and there is nothing on this for the 350z... but infiniti indeed does have a tsb. So strange. Anyways, the part number does indeed exist for infiniti, so I have 2 on the way.
Very odd. I wonder if nissan used stiffer bushings on the 350z.... I wouldnt think so but... I duno.
__________________
[ 2003 G35TT 6MT OB Coupe ] - APS Twin Turbos + APS Downpipes + APS Exhaust + CJM Stage 2 + Meth Injection [
Old 01-12-2009, 10:47 AM
Im pretty sure the 350z has this problem also, ive seen threads bout it.
Old 01-12-2009, 05:05 PM
ShanesG's Avatar
SPONSOR
2006 Infiniti G35 Coupe
Send a message via AIM to ShanesG
Damn same thing happened to my Lower Control Arms(1st pic) gotta replace it now!
__________________
PM For pricing or Text 818-653-2927
Shyne{Fitment Done Right}
Old 01-15-2009, 02:25 PM
Send a message via AIM to BlackWindEXE
so is it better to buy the bushings or the whole arm? i emailed the nismo website someone posted about which item is bought and never got a response. i'm hoping you guys can help because i have the same problem. and there is no way i'm going to infiniti to get this fixed.
also, is this a necessary fix? will these get worse and break? i don't mind the sound considering my car is loud as it is anyway. The main thing is whether or not this will get worse and my suspension will go to crap.
__________________
2004 G35 Coupe 6mt Laser Red/Brembos/Clear Corners/Ionic Grill/19" Black Racinghart R5 Pro/Z-tube/Popcharger/Motordyne Isothermal 5/16 Spacer/Circuit Sports Strut Bar/Grex shift/10" JL custom sub
Old 02-08-2009, 04:48 PM
Great question can someone answer that please
__________________
Volk.Tein.Brembo.Fujita.INGS.Nismo.Bassani.Ichiba. Broadway.
Old 02-09-2009, 03:34 AM
I can field this one... you SHOULD reaplace it without a doubt. Its metal to metal contact with the bushing pushed out like that not to mention it effects your toe and camber settings as well because of the serious movement in the suspension. Its not that your suspension will go to crap its more like your tires, when mine was pushed out i heard some serious clunking noise when i approached dips in the road and bumps as well.
Whats the best fix? I personally bought the Nismo transverse bushing from the website i provided and had them easily pushed out and the new ones pushed in. I did it this way because the price of both bushings was less than the price of 1 LCA... so i figured is do both sides for preventative maintenance with higher quality materials with the nismo part. If anybody else has questions please feel free to ask... my experience was very positive puchasing just the bushings.
__________________
“Las Vegas is sort of like how God would do it if he had money.” - Steve Wynn
Old 02-09-2009, 01:48 PM
Thanks for the response really needed it. So once you replaced them the clunk noise went away right ?
__________________
Old 02-10-2009, 03:30 PM
Absolutely, it was clear to see where the noise was coming from when you jack up the front of the car and realize oh **** my bushing is busted. I actually didnt even notice it till the car was on an alignment machine and the tech pointed it out and that the car couldnt be aligned till fixed.
Here is a link to the people i ordered mine from
LINKY LINKY
Its the lower transverse link bushing for $35.00/ each and the labor to have them pushed is is very minimal if you take the lower control arm off and take it to them, its very little work on your side and theirs. I know many leaned the way of buying a whole lower control arm because Nissan/Infiniti doesnt sell just the bushing in their parts department.
__________________
Old 02-10-2009, 03:34 PM
Jeff92se's Avatar
Can you review how the car drives before/after the Nismo bushing install? NVH increase? You replace all the bushings or just the one that was damaged? (but on both sides)
__________________
Coupe 19s ~ Hotchkis swaybars ~ Crawford V5 plenum ~ V1 hardwire kit ~ Autoenginuity OBDII & Nissan enhanced ~ Z front/coupe rear springs w/ Koni adjustable shocks ~ TS F-Spec reflash
Old 02-10-2009, 03:39 PM
ShanesG's Avatar
SPONSOR
^+1
Old 02-10-2009, 03:50 PM
LINKY LINKY
Im still confused dont mean to sound like this but your saying it was not the control arm bushing that you replaced??? And how come the link shows so many different bushings they all have to be changed???????
Old 02-10-2009, 06:29 PM
Quote:
Before the bushing install my cars front drivers side wheel had about an additional -2 degrees of camber because the suspension had been compromised with the slipped bushing. Driving was embarassing as to when i took dips and small bumper i would hear a thumping noise coming from my front suspension as if there something was knocking on my firewall with a hammer. From the first pic of this whole thread you can see where the thumping was obviously coming from with the metal to metal contact and when movement was introduced to the suspension with bumps or uneven pavement that it would cause the thumping.
After install my negative camber issues are gone and i was able to have the car aligned with no issues. No more knocking under and driving. If your looking for any change in handling i dont think you will find any as its only 1 bushing of many that are suspension related. But i will say its no longer embarassing to have people in the car, and the confidence knowing your suspension isnt broke is a plus.
As for what i changed, it WAS the front lower control arm bushing that is pictures in the beginning of this thread as PIC1. On the Nismo site THEY have it listed as the
54560-RRZ30 INFINITI G35 2003-2006 Front Lower Transverse Link Bushing $35.00
I purchased 2 of them, one for each side. Took about 10 minutes a side to remove the lower control arm and about another 10 minutes to have the bushings pressed in. A very simple process for a very common problem. And no i didnt change all the bushing and no they all dont have to be changed unless you want to. All i changed is the one i listed above because thats all that failed.
THIS ONE>>>>
__________________
Old 02-10-2009, 06:59 PM
ShanesG's Avatar
SPONSOR
Did you press them in yourself???
Old 02-10-2009, 07:15 PM
Quote:
Yes, a friend of mine owns a hydralic press
Click for link
I recommend just buying the press if you and/or friends do alot of wrenching yourselves since its so cheap (go halves on it). Good for bushings, bearings, etc.
__________________
  #30
Old 02-12-2009, 05:29 PM
Alright I check the Control Arm Bushings on both sides of the front suspension because Im getting the same clunk noise every one else is getting and the bushings look perfectly fine It bugged me because now I dont know what it is.
Hey D would you happen to know what it is ?
I have an 04 Coupe with Basic Tein Coilovers and Volks GT-C with Falken FK452 245/35/19 , Brembo Pack, Wheels Spacers.
Pls HELP ME!!
__________________
Tags
350z, 54570ac70a, arm, bushing, compression, control, diagrams, g35, g35x, infiniti, infinity, lower, nissan, number, part, rod
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
G35Driver - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Copyright ©2002 - 2008, G35DRIVER.COM All Rights Reserved.
Advertising - Terms of Service - Privacy Policy - JOBS
MyG37.com | My350Z.com | ZDriver.com | G35Driver.com
