best BBK bang for buck?
i have a base 2005 G35 coupe and my brakes are shot.. im about to get my tax return and am not sure what the best deal would be.. i hate the looks and performance of my OEMs..
what would be my best increase in braking performance while not spending $6k???
i dont wanna keep my calipers so its either:
OEM BREMBO kit w/ upgraded pads, rotors and lines
OEM G37S kit w/ upgraded pads, rotors and lines
Ksport BBK(most expensive outta my bunch at $4k)
Have you seen these yet? https://g35driver.com/forums/brakes/...-06-sedan.html
The best part is you can bet parts at any Infiniti or NISSAN Dealer.
on
106ft 60-0 on the heavier g37. Reason stands it would be less on the lighter G35 and 350Z.
I personally bought the g37 brakes and powder coated them. They will be installed on thursday. I also have the upgraded Project Mu Pads and stoptech stainless lines with Motul 600 fluid.
At this point, I will argue my G37 brakes will look and perform as well if not better than ANY other BBK on the market while still keeping $2k + in my pocket.
My only issue is the weight of the front rotors which I will admit is a lot. I will be swapping those out for the lighter 2pc rotors made by stoptech once they come out which should be within 2weeks or so.
Red Card Crew
Great info. Would you have a link to that? ie.. mag review? But you're correct, even if it matched the performance, it would prove that they are very capable even on the heavier car. I think the new Gs still have the RE050s too?
With a rotor dia of 14" in front, I'd guess they would make a great track setup also.
Post again when StopTech has those 2 pc units.
on
Dont have a direct link, but it was in the Motor Trend review of the G37S.... I researched digging through my past issues before I pulled the trigger on these about a month ago.
It taken so long between purchasing them, waiting on them being shipped (by Donkey it seemed like) to recieving them and having them powder coated and my own travel plans. They will finally be on by this friday at which point I will post a full review with Pics.
Yes, Im a lil excited.
There are a lot of worthy big brake kits out there The AP Racing brakes are great, the Stop Techs are ok sometimes, anything from K Sport sucks, period.
But if you are looking for bang for the buck, I think you would be hard pressed to beat the quality and price of the Megan Racing big brake kit front and rear. Or better yet the version of this BBK from Relentless Autosports with the upgraded pads and brake lines, and your choice of colors. Remember this version of this brakes are track tested and look great.
Red Card Crew
So in that case I have seen some big brake kits do better than others in one form or another in daily driving and in track use.
Red Card Crew
If you mean, very little "quantifiable" data then you are correct. A big brake kits purpose (other than looking good for some people) is that of repeatable use under stress with minimal amount of fade. They are supposed to disperse greater amounts of heat quicker than smaller stock brakes and hopefully allow for much longer pad use, since they are bigger and make lighter work of stopping and slowing down the car.
G37 brake upgrade should be the best bang for buck.
The Akebono caliper is much bigger than OEM brembo.
Then upgrade to a aftermarket 2pc rotor, SS brake line and high performance pads and you should be good to go.
As some one said before, G35 stops from 60-10 in 110~115ft and the G37 in 106ft.
The G35 with G37 BBK should stops much better since it's 200lb less.
FYI, Akebono is the brake manufacturer for McLaren Mercedes F1 team.
Just because their name isn't famous as Brembo and AP doesn't mean they sucks.
Size comparison:
Size comparison:
#30
When comparing the stopping distances between the G37 and Brembo cars you must also consider what tires (size, make and model) were on the tested cars. The quoted distances for both are well within the margin of the impact different tires (size, make and model) alone would have braking performance.
