best BBK bang for buck?
Old 01-27-2009, 04:15 PM
sheplex02's Avatar
Brakes best BBK bang for buck?
i have a base 2005 G35 coupe and my brakes are shot.. im about to get my tax return and am not sure what the best deal would be.. i hate the looks and performance of my OEMs..
what would be my best increase in braking performance while not spending $6k???
i dont wanna keep my calipers so its either:
OEM BREMBO kit w/ upgraded pads, rotors and lines
OEM G37S kit w/ upgraded pads, rotors and lines
Ksport BBK(most expensive outta my bunch at $4k)
Old 01-27-2009, 04:16 PM
O HELLA OEM's Avatar
GET THE G37 bbk
Old 01-27-2009, 04:17 PM
redlude97's Avatar
OEM brembo if you are concerned about performance
Old 01-27-2009, 04:20 PM
Jeff92se's Avatar
Red Card Crew
IMHO? oem Brembo on Racing Brake's 2 pc rotors for the oem brembo.
G37 setup is nice as the front rotor is 14". But that rotor also weighs approx 24-26lbs. On your 05, you would be adding a good 5-6lbs of roatational weight to each corner.
For all you pre-05 guy adding the G37 setup, it would be like adding a good 10lbs to each corner.
Old 01-27-2009, 04:23 PM
sheplex02's Avatar
i was told about the weight issue for the G37S brakes and i was hoping that me using 2 pc rotors would solve that issue..
wouldnt it?
Old 01-27-2009, 04:24 PM
Jeff92se's Avatar
Red Card Crew
It would if they were available. ARe they available?
Old 01-27-2009, 04:25 PM
sheplex02's Avatar
honestly.... havent looked thought they would be by now...
Old 01-27-2009, 04:26 PM
ShanesG's Avatar
G37 brakes...i believe they out performed the 03-04 Brembos!!!
Old 01-27-2009, 04:27 PM
GreenGoblin's Avatar
The goblin resurrection
To my knowledge there are some 2 piece rotors in the works but none are released as of yet.
Old 01-27-2009, 04:32 PM
sheplex02's Avatar
yeah i cant find 2 pc.. just some 1 pc sets..
Old 01-27-2009, 04:33 PM
Jeff92se's Avatar
Red Card Crew
My memory says the oem Brembos were 60-0 in around 110-115 ft.
What did the G37 Akebonos do?
ShanesG's Avatar
^yeah i believe COZ is making a 2 pc!!!
Old 01-27-2009, 04:34 PM
redlude97's Avatar
links?
sheplex02's Avatar
found some for the bremos of course.. i just want the best quality and performance without breaking the bank(no pun)
ShanesG's Avatar
Yeah i can't remember either, i just remember seeing a thread about it, and from what i remember the 37 brakes performed just as good if not better than the OEM brembos...i'll try and find the thread!!!
Quick Reply: best BBK bang for buck?
