Any one replace their lower ball joints?
#346
Hmm, alignment was done last year and still seems fine (0 drifting in either direction when driving straight, hell I can drive down a road with no hands if I wanted to).
I'll wait a day or two for the grease that was added to "settle in", if the sound is still there I'll have them check the caster angle. Thanks
#347
Creaking is still there, it's gotten louder. Doesn't happen when going over bumps, but when turning slowly (eg: Into driveway or parking spot) it's pretty bad.
edit: I'm going in to get a printout of the alignment. Anything specific numbers I should look out for?
edit 2: Just got my alignment printout and everything is in the green except camber
Camber is -1.3/-1.4
Caster is 7.9/8.1
toe is 0.02/0.01
Still don't know wtf this creaking is when I turn. The end links where checked once again. Anyone know what else it could be? I mean other than throwing more money at it and having the compression rods completely taken out to inspect.
#348
Justdefied
I had a similar creaking noises after installing Hotchkis sways, they put more stress on the OEM sway bar links during turns & speedbumps even though I was not lowered. Maybe your troubleshooting should include a sway bar end link lube using a grease needle on the rubber covered joints (two on each link). Simply puncture the rubber boot and inject a marine grease until the boot fills. It is a cheap & easy fix. If it works - great! if not then you have not lost much time or money. Hope this helps.
#349
#351
#352
Bit of a late response, but no, no excess wear on the inside of the tires. Really want to get this figured out before the winter comes.
Camber is -1.3/-1.4
Caster is 7.9/8.1
toe is 0.02/0.01
Camber is -1.3/-1.4
Caster is 7.9/8.1
toe is 0.02/0.01
Did you ever get this figured out?
#353
Had like 4 different people/places inspect, the only "answer" I got was from a Infiniti mechanic who said it's most likely the sound of the brakes slipping (and therefore creaking) but no way to tell other than replacing it..
My front rotor is warped now so I gotta replace it anyways so I just ordered new pads, rotors, hardware and Stainless Steel brake lines and I'm gonna be installing them probably at the end of the month and I'll report back if it fixes the issue.
#354
How in the hell does a brake slip? Not sure what that means, but good luck!
I put in some Z1 Motorsports arms when I did my coilovers and I've got a creaking/binding noise in the front right only and done know what it is. I'm going to swap back in my oem A arms and see if it goes away. We'll see.
#355
For your Z1 arms I'd check if they use the Energy Suspension polyurethane bushings, those have been known to squeak after a while. A couple people on these forums complained about them, they also mentioned the noise gets slightly worse in the cold. So if that's something that you noticed it's probably the bushing on the arms; although it doesn't necessarily mean something is wrong, it's just a character trait of those bushings for some reason.
You could also look into replacing just the bushings, people seem to have better luck with the Whiteline ones as far as noise goes.
#356
Can someone please link me to a lower ball joint that is the correct size for a 2006 G35 5AT Coupe RWD stock suspension?
I prefer to get a decent one the first go round and correct size as some mentioned they got longer ones than original.
#358
I have an 06 and want to make sure I'm getting the correct part. Has anyone used MEVOTECH MS30506? If so how has it been holding up?
#359
On ebay they make it look as if all years on the G35 it's the same ball joints. Even autozone website shows as if the duralast brand ball joints will work on all years. But some people noted in this and in the 350z thread that the ball joints are different in 05+ cars.
