| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools | Rate Thread | Display Modes |
brembo help
hey guys i had my brakes checked out in may and my brakes were fine and starting about mid july my brakes started squeaking only when im braking from like 5mph to 0 any suggestions on how to get this to stop
__________________
MD, JWT, NRG, EIBACH, IONIC, INVIDIA, R&D, NIFFTYSHIFTY, PROJECTORS, TINT |
New pads! New rotors! Could be a few things causing a squeal though!
__________________
2009 G37S Sedan RWD, Blue Slate, Nav, Premium, Auto |
if your on stock pads and rotors, they are known to squeal. just change your pads to aftermarkets, if your rotors have some miles on them you should change that too
__________________
National G Club :SOVA Chapter ll Sponsored By Citymunky Motorsports |
Quote:
yea they are the stock brembo ones...but its not a subtle squeak its LOUD. my friend has an evo X that has the stock brembos and his dont squeak so i dont know if there is something wrong with my brakes or something
__________________
Sometimes pads are defective. Sometimes they are just noisey or ****ty pads. If they are high performance pads, it may be normal to squeal, depending on which ones you got. Sometimes it's the rotors that cause the squeal. Could be worn or loose hardware. It's hard to tell without doing an in-person inspection. Try a couple 60-0 hard stops to see if it goes away!
__________________
Quote:
__________________
Take the pads out and put some 3m brake lube on the sides and backs of the pads per the FSM. Mine squealed from 5-0mph a few thousand miles after new, but haven't since. I make sure to use plenty of brake lube. I assume you're on OEM Brembo pads? If not, and you're on aftermarket pads, then you may have left off the shims, which are needed for noise reduction.
__________________
2004.5 6MT DG/G Coupe|Brembos|Premium|Aero|Sirius|Autovation Pedals|5/16" MD ISO Spacer|GroundingGear|Stillen Sways |
| Tags |
| brembo, lube, pad |
| Thread Tools | |
| Display Modes | Rate This Thread |
