Official Coilover quick review thread
Mods, planning to get this stickied, I see a lot fo threads asking what coilovers ride best, what offer this drop etc etc. So everything can chime in and we'll add to the criteria as we go. (Similar to the strut bar thread)
Coilover: Brand and Model
Style: True or OEM
Spring Rate:
Drop potential: How low will it go
Adjustability: How easy they are to adjust
Stiffness: Compared to OEM
Harshness: Compared to OEM
Price point: How much can they be found for use- How much new
So if anyone else wants to add, that's all I can think of that matters right now, I am going to keep and eye on this thread and every time a new coil comes up, I will add it to the original post. Please use the format above. If you can not answer the question put N/A.
SMA
Coilover: SMA
Style: OEM
Spring Rate: 10k 8k
Drop Potential: You'll want more from the rear, front is sufficient
Adjustability: Rears are easy, front the coil needs to come out of the car
Stiffness: Much stiffer and better feel
Harshness: About the same as OEM
Price point: $700-$1200
Tanabe
Coilover: Tanabe Pro 5
Style: OEM
Spring Rate: 10/8
Drop potential: Modest drop 1.5" all around for coupe, 2" for sedan
Adjustability: Fronts easy/ rears easy for sedans with reclining rear seats. W/O reclining seats rears must be removed to adjust dampening.
Stiffness: Good improvement over stock with very smooth ride at low dampening settings
Harshness: Car feels much better planted but with no harshness, very comfortable ride.
Price point: Never seen a used set, new ~$1400
Tein
Coilover: Tein Basics
Style: OEM
Spring Rate: 9/9
Drop potential: Can't slam it with the coupe, but for the person that wants a nice drop it will be good enough. You can get lower in the rear by doing a spring mount mod.
Adjustability: No dampening adjustment available with these coilovers.
Stiffness: Been a while but I liked them. They didn't have any dampening so if you're trying to stance the ride out, forget it.
Harshness: Never really felt harshness with these.
Price point: Used around $600. I say look into other coilovers around the same price range or a little more for something better.
Function & Form
Coilover: Function & Form Type II
Style: OEM
Spring Rate: 10/8
Drop potential: I couldn't turn my wheel (coupe 19's on sedan) or back out without scraping from a friends garage and I still had room.
Adjustability: Same as most coilovers. Easy in the fronts, difficult in the rear unless you have a sedan with reclining seats.
Stiffness: Somewhat stiff but there seemed to be too much rebound.
Harshness: I didn't really care for them. I loved the drop, but for an aggressive setup, I've owned better.
Price point: Under $1k new
Ohlins/Impul
Coilover: Impul Ohlins (PCV)
Style: OEM
Spring Rate: 10/7
Drop potential: You won't be slammed. Max drop on a sedan is about 2.5"
Adjustability: Very easy. If you have wide openings on your wheels (like OEM 19's), you can stick your hand through it and adjust dampening in the rear from the bottom.
Stiffness: They seemed to be pretty stiff, but they maintain comfort.
Harshness: Harsh doesn't come to mind AT ALL. No matter how stiff or soft the coilovers are set to, it's a smooth ride. Great coilovers for tracking and daily driving.
Price point: Low to mid $2,000 range for a used set.
HKS
Coilover: HKS Hypermax III (non-sport)
Style: OEM
Spring Rate: 9/9
Drop potential: Never tested fully, but it got lower than the Ohlins and still had room. Nothing like the F&F. On a scale of 1-5 with 5 dropping the lowest I'd give it a 4.
Adjustability: Very easy. If you have wide openings on your wheels (like OEM 19's), you can stick your hand through it and adjust dampening in the rear from the bottom. Just like the Ohlins except the **** is a little smaller.
Stiffness: Not as stiff as the Impul Ohlins, but still good while maintaining comfort.
Harshness: Didn't feel harshness at all. Quite smooth.
Price point: Low to mid $1,000 range for a used set $1800ish new
Coilover: HKS Hypermax III non sport
Style: OEM
Spring Rate: 9/9
Drop potential: i would say you can go almost to the ground with these, ive never fully maxed these out to see full drop capability
Adjustability: very easy compared to other styles on the market
Stiffness: coming straight from stock suspension to these coilovers will be a huge difference, but its not too stiff where it becomes uncomfortable.
Harshness: dont feel harsh whatsoever, the ride is perfect for me.
Price point: used around 800-1,000 new around 1500
Stance
Coilover: Stance GR+ (true)
Style: True
Spring Rate: 12/5 (But with my setup it's a 14/8)
Drop potential: These will get low. If you want to stance your car out, these are a great choice.
Adjustability: Like most coilovers with dampening adjustment in the rear, if you don't have a sedan with reclining seats you will need extenders.
Stiffness: My review will be different than most. I swapped the springs out through Stance to have a 14/8 spring rate. I did notice a bit of a difference. I ride low, but I feel they can be stiffer. I haven't tested any other coilovers driving at this height with my wheel setup. But I would have to say at the ride height, they are stiffer than the F&F Type 2's.
Harshness: As a tip, don't set to full stiff (you shouldn't with any coilover). I have mine set to 4 clicks below full stiff and it improved rebound quite a bit. For the most part I have a good ride. Passengers don't complain, but if there are a lot of bumps and dips, I tend to bottom out and it gets a little rough. Keep in mind I have extreme negative camber and a lot of stretch.
Price point: Low to mid $1,000 range for a used set.
Style: OEM
Spring Rate: 10k/12k
Drop potential: Pretty damn low, almost tuck an 18 without collars out on a sedan
Adjustability: Can be done on the car and easy to loosen the collars
Stiffness: Stiffer, but with the dampening backed off quite nice.
Harshness: You feel the dips and you definitely feel some impacts, but not bad compared to stock.
Price point: Around $1400 new, $1000 or so used.
KBee
Coilover: KBee
Style: OEM
Spring Rate: 12K/12K (Swift Springs)
Drop potential: Frame Banger
Adjustability: Height is as easy as any coilover. Dampening for the front is easy, The rear needs to be off the car.
Stiffness: Ridiculous on full still. Pretty comfortable on full soft.
Harshness: You can feel the road beneath you, but you don't hate it.
Price point: These are extremely rare JDM coilovers. They are only available in Japan. @$1200 US.
Greddy
Coilover: Greddy Type S
Style: OEM
Spring Rate: Front – 10k; Rear – 8k
Drop potential: Front will lay a nismo bumper on the ground. Rear: spun down will set the fender right past where the tread is on a set of 285/30/19. Remove the adjustment collars from the sleeve and you can tuck 2/3 of the way down a 285/30/19
Adjustability: spring height just take the wheels off and use the tool to loosen the collars and spin them to where you want them. Strut stiffness front: easy, it’s at the top of the strut (be wary of some strut bars not clearing the adjustment ****) and rear you have to take the strut out if you want to change it, or cut a 6.5mm access hole to run the extended adjustment **** into the trunk.
Stiffness: compared to OEM of course it’s a rougher ride. You tend to feel the road a lot more, but it’s not “bouncy” or “rough” at all. Larger bumps are a pain, but that’s the case with any modified suspension . Considering it comes with 32 point adjustable stiffness with the struts, and because you can also adjust where the strut sits (meaning you can dump it damn near to the floor and still have fantastic strut travel) it actually rides better than most coilovers I’ve experienced while still being able to let the car handle like a champ, and I live in an area that has HORRIBLE roads. So for me to be able to slam it in the dirt and drive it daily without back problems says a lot. It’s also a FUN set up to take on curvy roads, autox etc., I hit the Tail of the Dragon twice a year and have no trouble or complaints at all.
Harshness: It follows the road... if the road is smooth, you’ll never notice anything other than how tight it makes the car feel. If the road is rough or bumpy, it certainly changes the comfort, but it’s not bouncy and won’t throw you everywhere. If anything it helps you control the car more by taking the kit and recovering quickly. The coilovers actually handle adverse conditions well, so “harsh” is not a word I would associate with this setup. Large bumps themselves are going to be rough, but again... that’s for all coilovers.
Price point: used: $1000ish?; new: $1500
Style: True or OEM
Spring Rate:
SMA
Coilover: SMA
Style: OEM
Spring Rate: 10k 8k
Tanabe
Style: OEM
Spring Rate: 10/8
Tein
Style: OEM
Spring Rate: 9/9
Function & Form
Style: OEM
Spring Rate: 10/8
Ohlins/Impul
Style: OEM
Spring Rate: 10/7
HKS
Style: OEM
Spring Rate: 9/9
Style: OEM
Spring Rate: 9/9
Stance
Style: True
Style: OEM
KBee
Coilover: KBee
Style: OEM
Greddy
Style: OEM
The following 5 users liked this post by 4DGS:
GXXXV X (06-20-2011),
lsmooth81 (06-06-2011),
thegreatkwijibo (10-17-2012),
TunerMax (02-22-2012),
_Nick (10-11-2014)
Great idea....will chime in when I get back from lunch. Reserving post
Style: OEM
Spring Rate: 9/9
Still had room to lower
On 20's:
On 17's:
Style: OEM
Spring Rate: 10/8
On 19's
Style: OEM
Spring Rate: 10/7
On 19's
Style: OEM
Spring Rate: 9/9
On 19's
Style: True
Still have room to lower with 18's and 20's. Keep in mind fenders in the rear have been flared upward as well and front camber is -5.5 and rear is -8 so it will look lower/more tucked if they had more positive camber like most setups. In pic of 19's, coils are maxed out (without removing any rings).
With 18's
With 19's
With 20's
Style: OEM
Spring Rate: 9/9
On 20's:
On 17's:
Style: OEM
Spring Rate: 10/8
On 19's
Style: OEM
Spring Rate: 10/7
On 19's
Style: OEM
Spring Rate: 9/9
On 19's
Style: True
With 18's
With 19's
With 20's
I drove ttrank's car solo
Received 1,486 Likes
on
Style: OEM
Spring Rate: 10/8
Price point: Never seen a used set, new ~$1200
I can't say enough great things about these coils. Their only drawback is the limited drop, but that can be helped out by removing collars. Definitely not for the slammed crowd. If a decent drop and a better-than-stock ride is desired these are a great option.
Style: OEM
Spring Rate: 10/8
Not sure if you want to include this, but this was created by a member a while back. Lots of info on spring rates, some ride height, some info regarding reviews, and it has some product construction specs.
https://g35driver.com/forums/brakes-...w-updates.html
Also, I updated my post
on
Style: OEM
Spring Rate: 9/9
Style: OEM
Spring Rate: 9/9
Same here man. #2 on the list that I've owned. Only advantage over the Ohlins I'd say is the amount of drop you can get with them. I wish they were true coilover types. Would take them over the Stance GR+'s any day.
What coils are you gonna run now? Or is it a secret till the review comes out?
