Questions about Air Ride suspension ask here
#496
Re: Air Suspension
Anybody dealt with AVS or Bagriders? Preferences or opinions?
Looking to buy UAS bags and brackets for the front of my G sedan, as well as tank and compressor. I have bags, losses, and valves for the rear already out of prior minitruck project I sold.
How much lift does front get out of the aero sports?
Venom, what system is your buddy selling and for how much?
#498
I will be ordering some bits from bagriders... I have Tein EDFC and I would like to keep it... BUT I may not be able to... They are willing to custom cut brackets anythind I need... If I cant keep them, then what I will do is likely do BC coils with bags on top... BUT we will see... I can vouch for bagriders though!
#499
#500
#503
Another question to anyone who has air installed on a coupe, can you tell me how you have routed the air lines to both the front and rear bags from the trunk?
Have you gone underneath the car to the front or through the interior? I've found the two large grommets under the trunk liner which I'd prefer to use instead of cutting more holes.
I've read pretty much every post in this thread and can't recall seeing anything about this. Any details would be super helpful, thanks.
#505
I'll do an install thread once it's all done to help others out in the future.
#506
#509
losing air from unit
I have a older Air Ride Technolgy system...here's my problem. I would set the height I wanted and it would hold all day long, but as soon as the car sat all night, I would go out in the morning and it was listing to the right side front. Checked all the connections and used soap water to look for leaks. The line going to the front rt. bag was loose, tighten it and found no other leaks. Now as of today the left rear is listing down. I'm lost.... that's why I'm here. Funny thing is if I inflate the bags all the way up it holds. I'am not a real mechanical type guy. I bought the car with the air ride already installed. It is a 62 Chevy BelAir. Can someone point me in the direction I need to go. If not, where can I take It to be looked at ? I've went to a few garages in the area no one seems to want to look at or they tell me they know nothing about air ride systems...Any help would be appreciated........Thanks
#510
Front passenger bag not inflating
Hello i just picked up a 04 g35 with an air bag system idk which one , but all seem to work fine except the front passenger one ...I push the nuttton to lift it and it won’t lift , it’s too low to drive like that I have to even the whole car out so it can be driveable. What can be my problem . Can I just by pass the front passenger air bag and put back the stock one and keep the rest of the three bags there ? Is there a way to keep it permanently lifted up maybe 2 inches more ?
