ABS sensor or wheel bearing / hub ?
Hi. I am new guy on this forum, tried to search a lot of topics, but did not find the answer i needed. Here is my situation: I have 2004 G35 sedan, RWD. I had ABS, SLIP and VDC lights on. Went to service shop and got code C1108 - Front Left Sensor 2. I took off the wheel, and checked out the sensor - looks fine, clean and good condition. But the ring that it points to has couple pieces that broke off. Could this be a reason? I am not sure but I think it is a bearing from the hub / wheel bearing assembly ? My question is - Do I need to replace the whole hub/bearing assembly, or this ring can be replaced individually ? On other car I have there is a tone ring with teeth, but nothing like that on infiniti.. where does the speed sensor gets its signal from? the bearing?
Let me know please. Thank you for help !
I am attaching couple pictures. Also - can I just unplug the speed sensor, ? will the lights go away or not ?
I drove ttrank's car solo
Received 1,486 Likes
on
I don't think there are any other options. Looks to be a pretty simple replacement procedure assuming you have a tool to separate the lower ball joint. In my experience the upper one doesn't put up much of a fight.
Ok., I replaced the wheel bearing / hub. The light is gone, and everything is fine ! Thank you everybody for help ! I took some pictures while I was doing it.. I wanted to post DIY on front wheel bearing replacement, but I dont have rights to post to that area yet.. If anybody has questions, let me know.
rezendvous420
05-31-2020 01:26 PM
