A brake question
A brake question
Hey I have diligently looked in the forums and tried to read as much info as I could, however, I don't see where the answer lies.
1) I need to replace the rear rotors and pads on my '03 G35 Sedan... that being said, can I replace it with aftermarket rotors and pads, without changing the calipers, lines, etc...? I want to get some slotted rotors, but I want to make sure that I do this right... the ones I was looking at were supposed to be stock size... so not big brakes or anything.
2)Can I only do the rears and then do the fronts on a different occasion (like when they go out), ?? Or do I need to do them at the same time as I do the rear?
nissanlady (10-10-2013)
I was thinking of going with something like this...
CPZ G35 Rear Rotor starter kit - Cross Drilled/Slotted
This is my Daily Driver - I haven't been to the track in years and don't plan on going much with my DD, however, I want something durable if I do go and that will not affect my daily driving.
Opinions? Recommendations anyone?
nissanlady (10-11-2013)
Hun, you want slotted only. The slots allow hot gases to escape(even though the split in modern brake pads do this), provide the pads a cooling interval, and provide a fresh cut or glaze while braking. They will however eat pads a little faster. With holes your saving how much weight, maybe almost a pound a rotor? They will make the rotor weaker, and providing less contact area for braking. Think about how much contact surface u would be loosing if u went drilled and slotted.
