Spring Questions
Spring Questions
Here's info I pulled from the sticky'd spring thread:
NOTE!: Any aftermarket 350Z spring will lower a coupe a additional ½” over and beyond the published drop amount for the 350Z.
Oem linear springs
G35 coupes 2005/2006 with oem 19’s only. 350Z 2004.5 to 2008 (revised suspension) Front:314 Rear:427
Tein S-tech 350z
SKP26-AUB00(fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher Spring rates in LBS 386/402 (estimated front intial rate is 327lbs)
Tein S-tech G35
SKP30-AUB00(fronts are progressive, rears are linear) coupe drop 1.2"/.9" sedan drop 2"/1.3"
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
SO, I need some expertise here, if my OEM rear LINEAR springs are 427 lbs (I'm guessing this is the amount of weight needed to compress the spring?-pls correct me) and the rear LINEAR Stech g35 springs are 274, does that make them much softer? I'm going for a slightly stiffer than OEM ride quality. Answers I get from this will help me decide which springs to get. Thx in advance.
PS if u have 350z s techs pls let me know how they worked for u
Oem linear springs
Tein S-tech 350z
Tein S-tech G35
I have a set of Tanabe NF210 springs on my coupe they dropped my coupe 1 inch in the front and .6 inches in the rear. I'm using the factory struts and shocks since they only had 30,000 miles on them when I installed the springs. The ride is a little firmer than stock and the drop is mild but noticeable and my car handles extremely well.
I've been using Tein 350Z H-Techs for 6 years at least, the ride is perfect even when I was using OE shocks! The S-Techs will lower you about 1/2" lower than what I'm running. You will need a complete camber kit front and rear, figure that into the cost of lowering your ride! Check our Marketplace under vendor suspension for the kit. SPL offers the most adjustment to bring your alignment back to OE specs!
Gary
Gary
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
05-31-2016 01:56 AM
joel extreme
SOCAL Meetings & Events
08-07-2015 03:09 AM
