Did anyone changed SS line for front brake? HELP!
Old 05-28-2014, 03:08 AM
mliu66's Avatar
I wanna upgrade to SS brake line. Today I checked my front brake (04 G35 sedan, sport package, non-brembo) and found the brake hose is a 3-piece line! The upgrade SS line is a 1-piece line. How would I fit this on my brake?
Anyone upgrade to SS lines?
Old 05-28-2014, 10:34 AM
LoSt180's Avatar
Just replace the whole line between the hardline on the body and the brake caliper. The SS line should have 2 brackets attached, both those up where the blocks used to be on the stock rubber line.
Old 05-28-2014, 01:28 PM
mliu66's Avatar
So I will take off the rubber lines and use the bracket to hook the new SS line to where the rubber lines was hooked?
Is there any requirement on how to hook it up? The SS line is shorter than the stock 3-piece line.
Old 05-28-2014, 02:10 PM
LoSt180's Avatar
Yes. Here is a picture of the brake lines I have, basically one long hose for the front:
Check this post for routing in the front, should make sense when you get the wheels off and look at how the brake lines run. -> https://g35driver.com/forums/6724236-post16.html
Litterboxer1 (07-13-2020)
silencedeyes
Brakes
11-26-2015 05:36 PM
kinetek
08-03-2015 04:25 PM
wojowojo16
07-27-2015 09:57 AM
newg37
07-26-2015 09:32 AM
mushu
07-15-2015 03:55 PM
Quick Reply: Did anyone changed SS line for front brake? HELP!
