Rear wheel bearing replacement?
I am seeing bearing with ABS and w/o ABS does it matter which one to get since I thought, both coupes and sedans were equipped with ABS from factory. I have a 2004 sedan thanks in advanced.
for example:512346 Axle Bearing & Hub Assembly, Infiniti G35, Nissan 350Z, Rear Non-Driven without ABS off www.amazon.com.
The ABS ring on a 350z and G35 are located on the rear CV axle close to the differential, not near the hub. That is the wrong part. It is rare to find the hub and bearing assembled, to my knowledge only one seller on ebay offers the combo all OEM brand. You will have to have the bearing pressed into the hub if you can get them out on your own.
http://www.partsgeek.com/catalog/200...l_bearing.html
Any brand will do, all of the timken brand ones I've purchased have not lasted long at all.
rezendvous420
05-31-2020 01:26 PM
