Several random brake questions
I have an 03 Sedan. I'm replacing the calipers and rotors. I was lucky enough to get 05 fronts off ebay for $13.50. I'm now looking for rear calipers. For some reason the used 05s seem to run more than early G37.
I know I can bolt up the rear from a G37 so I am looking at going that route. I am confused on what kind of rotors to get. I dont track the car so I just need something that will hold up. I want a bigger rotor because I have 19s on my car.
Any feedback on good rotors? I was looking at Centric. From what I have read they make the blanks for other companies. Also any recommendation on everyday pads?
I've seen that some members have used Centric rotors and the inital reviews seemed good. Im curious as to how hold they hold up.
Alot of people like the Hawks HPS, but it has bad cold bite. So it may not suit you if you live in a colder area. *Subjective as per Gary *
And I only ever heard good things about the centrics. They have a very good reputation from what I've read. I myself have just plain OEM for both pads/rotors.
As for your G37 question... I have no idea.
Alot of people like the Hawks HPS, but it has bad cold bite and gives a lot of brake dust. So it may not suit you if you live in a colder area.
Gary
I love it when members have opinions about products they've never used and only post what they're heard! I've been running HAWK HPS pads for 8 years, they're not effected by cold weather and leave very little dust on my wheels. The do require doing the "Bed In Process" which only takes 10 minutes of your driving time. (Search) Rotors, you can find a variety of brands on our Marketplace under vendor brakes. I've been using DBA rotors that are slotted/drilled, they're designed to run cool and work well...which they do! Stay with OE diameter rotors, going larger will require more $$ won't stop any better.
Gary
Gary
You probably want to replace rears with the same brand/type pad once the time comes. I bought these Bendix ceramic pads and they will replace my OEM pads when the latter wear out in a few months. Bendix pads a pretty well regarded and offer a one-time free replacement - so you get two sets of pads for the price of one. If going with Hawk pads recommend getting ceramic instead of HPS as HPS have a poor cold bite.
kinetek
08-03-2015 04:25 PM
BlueBelleG35x
07-23-2015 02:10 PM
