Trouble Adjusting rear coils
After an hour and a half of messing with my rear coils to get them to be less bouncy/stiff, I'm still left with a harsh ride.
I've followed every step to correctly adjust rear ride height, first I adjusted spring height, next I bolted in the spring cup, then with a jack I set pre-load to zero so its nice and snug, then I add a pre-load of about 10mm, lastly I adjust the shock to match the hole.
But the problem was that when I chose the ride height of the springs that I wanted, my shock ran out of room to go higher up.
The bottom fork was filled up and I wasn't able to go any higher, So then I adjusted the spring to be taller so maybe I could fit it and tried again.
Once I lowered the jack, I wiggled the spring and once again, It was loose.
Ive tried everything to make sure the springs are nice and snug while keeping the car low.
mjfenix
08-17-2017 05:49 AM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
netcbc
07-24-2015 11:25 AM
