G35x lower ball joints
#31
Just to be clear. Infinitigeex, are you saying that a rwd balljoint such as
http://www.ebay.com/itm/2-Premium-Fr...66ef73&vxp=mtr
will fit on the x, with little or no modification? I am in need of two, and in canada the dealer is selling the knuckle with balljoint for $500 a pop. 50 for a set would be awfulll nice.
I purchased from here -- though it looks like the seller is using a different supplier now.
I bought mine from http://www.ebay.com/itm/New-Premier-...item43d0a34b25
I received MTC ball joints. I asked them after I received them from the seller and they said it wouldn't fit the AWD models. The seller was adamant that it would fit AWD models before and after purchasing.
Hey guys. I read the thread but am not sure if you came to a conclusion. I got an 04x and i need front lower ball joints. Can someone please confirm that the 2wd Mevotech bj's will fit on an awd. Or any brand for that matter. I REALLYY don't wanna fork out 500 a pop at the dealer.
The following 2 users liked this post by InfinitiGeeX:
E_TRANE (04-01-2015),
Rodney Bryant (05-26-2016)
#32
NH-G35X-04 (04-05-2015)
#33
First post in the forums here but following this I'm also in the same boat as I need both. My x has 180 k on it. Mechanic says it needs a two full spindle jobs. Also claims it needs upper control arms and front passenger side rear control arm. I went out and researched and bought the parts specifically for my 04 x and the mechanic claims none of them fit??? My buddy is a mechanic for Porsche and has a lot of experience in imports so I'm going to have him look at it. In the interim, here I go into the forums for information on that stuff.
Rodney Bryant (06-22-2016)
#34
Not for AWD
OK guys. Somebody double-check my work here, preferably with pictures which I neglected to take the other day while I had front suspension torn apart. Is this TRULY the correct ball joint, and, if so, is this the one referenced over here in this other g35driver thread which required additional washers to clamp down properly?
http://www.ebay.com/sch/Ball-Joints-...G35%20X%203.5L
https://g35driver.com/forums/brakes-...-joints-2.html
I may be mistaken .. but ... I don't think so .. First of all, they look too small comparing the castle nut to the base .. secondly I believe that in the description below it says "Important notes: Except All Wheel Drive X models" Please please everyone keep looking!
#36
#37
Going to find out if these work
Purchased two "premium" ball joints on eBay BJ61035. Seller says they will fit all models and I asked specifically for my 04x AWD. Also picked up a brand new OEM spindle from Infiniti because I don't want to get this thing apart and find out these ball joints won't work. If this ebay purchase works I'll just return the spindle to Infiniti and pay the restocking fee. If they don't well then I'm out 75.00 for the ebay purchase but it's worth a shot.
My buddy who's a mechanic with Porsche will do the work in the next week or so and I'll keep you posted how it goes.
#38
MAS BJ61035 Ball Joint a go for AWD??
Hey Guys,
Went to do Front wheel bearing this weekend but ended up having an issue getting the lower Ball Joint unbolted. The cotter pin wouldn't budge - Tried to break it off then spin the nut up - In the end, I tried to just cut the nut off but ended up destroying the bolt to get the sucker off - I tried the Autozone balljoint, only to find it is not the right part.
Has this MAS BJ61035 been proven to work for the AWD g35's??
Thanks in advance
Jim
Thanks in advance
Jim
#39
Here is the bottom line....they pretty much all fit. The above ball joint that I posted the pic of fits and I ended up finding Mevotech ball joints for RWD model....it also fits. Bought a OEM knuckle to compare before we installed. Both were the exact same length. However the bushing that came with the part I showed above did not fit.fortunately the bushings on mine were still in good shape regardless. The mevotechs did not come with the bushing. It all worked out for a grand total of 450.00 for labor and parts . Two weeks in and no noise
#40
#41
Great news , please post what ball joint you ended up using and keep us posted on how it goes. BTW....you don't happen to have the part number for the bushing?
#42
In comparison from the original ball joint, the Duralast version had a slightly smaller screw thread, but the taper matched at the bottom. With that, the bushing should fall into place once it's all torqued down.
#43
#44
#45
Lower ball joints for 04 G35x
I'm in need of ball joints for my 04x and I'm very happy I found this thread. I recently bought the BJL148 from Autozone and I also bought the MAS 61035 off of ebay. I want both just in case something goes wrong where they don't fit or something. For those who installed these types of ball joints, did everything fit ok and how did they hold up??? I'm gonna try and get them fixed this weekend.
