Different pads on either side?
Old 07-03-2015, 08:59 PM
hassassin's Avatar
Hey guys,
I recently picked up a used set of akebono BBK calipers that came with pads and rotors. I have been having weird vibration problem under braking at highways speeds. I was assuming that the rotors might be warped therefore causing the vibration. They look pretty much new and seem to rotate uniformly.
So I decided to take a look at the pads, and I noticed that 3 of the 4 corners had EBC yellow stuff pads with at least 75% life left, but the last corner (driver front) had another brand/style of pads. Now I have NO idea why one of them is different but could this be causing the vibrations due to uneven contact between sides?
Also, I have this has been causing the balance weights to fall off on the front driver wheel, which leads me to believe that the vibrations have something to do with that corner.
Any help and suggestions are greatly appreciated.
Cheers
Old 07-11-2015, 02:34 PM
hassassin's Avatar
No ideas??
Old 07-14-2015, 01:15 PM
Spartan268's Avatar
There's only one way to find out and that's to replace the 2 pads from that end of the car. You can try just doing the one corner pad for the sake of it.
As far as my brake guy always tells me, what you do on one side, make sure you do the same to the other and it's identical.
Old 07-14-2015, 02:31 PM
mushu's Avatar
Your assumption of warped rotors is most likely the issue of the vibration unless your wheels are not balanced or some issue with the tires wearing uneven. I'm sure someone here can discuss the variety of pad compounds, but uneven wear in the brake pads still leads to what the condition the rotors are in. Check and balance tires, get rotors resurfaced, slap on new brake pads, bleed brakes (if necessary) and bed in the pads and rotors. Good luck!
Old 07-14-2015, 03:08 PM
ScraggleRock's Avatar
And you had NO vibration like this before the install? And does the one odd brand pad have the same meat as the other 3 corners?
Old 07-18-2015, 04:27 AM
hassassin's Avatar
Ya, i had no vibrations before the install. Im getting the rotors resurfaced and I also have new pads on the way. Im gonna get all tires re balanced too.
jsimonk
12-22-2023 03:49 PM
flytim3
07-29-2016 10:17 PM
g35Serge
09-30-2015 11:43 PM
miata007
08-17-2015 04:36 PM
emorehs
07-17-2015 09:45 AM
Quick Reply: Different pads on either side?
