Squeaky noise on driver side.
Old 07-29-2015, 12:16 AM
Jussaku's Avatar
I hear a squeaky noise on the driver side when I bounce the car up and down is that the control arm bushings going out or is it the control ball joint? It only makes the squeaky noise when I driver over bumps and I have tested the car by pressing down on the car.
Old 07-29-2015, 11:41 AM
UR2EZ's Avatar
it's probably the lower control arm bushings, on the inner-side. if you haven't had these replaced you need to, this is the most common worn-out item on the G and causes inner tire wear, which you may not notice until it's too late.
order them on amazon (whiteline) then have someone install.
Jussaku (07-29-2015)
Old 07-29-2015, 11:45 AM
UR2EZ's Avatar
rezendvous420
05-31-2020 01:26 PM
Bean_VQ35DE
07-22-2015 07:06 PM
tehmoonrulz
07-19-2015 10:44 PM
Quick Reply: Squeaky noise on driver side.
