Overheating drivers rear??
2004 Infiniti G35 Sedan
So I was on the highway today, and the car started shaking as if I had an unbalanced wheel. Got out and inspected it and only the drivers rear rotor was very very hot and smelt as if it was burning. I rebuilt the brakes this evening, lubed both pins and ensured that the piston was moving freely. All the axels and driveline seem to be in good shape. Drove home after the rebuild and the car feels normal however still has a lot of heat from just the drivers rear. Any ideas?
Thank you!!!
Thank you!!!
Thank you!!!
Thank you!!!
Thank you!!!
Thank you!!!
I had the same problem about 50k miles ago, drivers side rear. I had discs and pads replaced on both rears and a new caliper on the one that was dragging. The other day a heard some metallic noise and thought I need new pads. I checked and same side running hot again so I pulled them out and replaced the pads, cleaned all the components real good and put back together. That side is still hot, though not as much. Any ideas? Seems like a coincidence that it is on the same side even though a different caliper.
thechitoguy
Forced Induction
10-17-2015 04:14 PM
inexorable
17 Inch
09-24-2015 10:43 AM
