SPC Camber kit on G/Z combo
I found a member that is selling me their G/Z combo for my 2004 G35 sedan with sport suspension. I was then offered by another member that they had the SPC camber kit for the combo. My question is, is this kit really needed as the sport package comes with a negative camber set up for it to perform better from factory. Or is this for the G's with the stock suspension? I also have 235/50/17 (wider than the stock 215/55/17) tires on the sport 17" rims in the rear.
I have 2003 Z springs and 2007(?) coupe rears on my 2004 Sedan with sport (red) shocks. It was a perfect fit with no need for a camber kit (but it does "max out" the limits of the stock adjustability).
I'm running 19" Rays rims, with 245 40R19 tires on the back and I forget on the front). It's perfect. I wouldn't change a thing.
I usually drive my car short distances just a couple of times a week (I have a motorcycle, too). But for the past couple of months I have had a very long daily commute for a temp job out of town - logging about 1500 miles a month. I was worried the firmer ride wouldn't be as comfortable on regular long distances, but it's just as comfortable as the stock set-up (plus so, so much better for aggressive handling and a much nicer profile).
So before I use my G/Z spring combo I have 235/50/17 on all 4 corners. Will they rub with this combo? I'm a great DIY with cars done all my own mods but the tire part I can never get lol. Should I get spacers and what size? I'm going to also ask around to see. Thx ahead!
As for spacers, my instinct is if you make the rear wider you are more likely to get rubbing.
sanchamp411
12-30-2015 07:49 AM
rmb2005g35
12-29-2015 11:26 PM
