Just did brembo swap and VDC and SLIP lights on
Old 02-12-2017, 11:54 PM
Karl Horn's Avatar
just finished my brembo swap and my VDC and SLIP lights are on. Brand new pads, rotors, SS lines and brake fluid is full. Bleed the brakes like crazy (went through about 32oz of fluid) and have no air in the system. Haven't driven it more than 3 feet since the swap. Just tested the grab of the brakes. Anyone else know what the issue could be? Should I drive it some more before worrying? Maybe reset the ECU? 03 G35 sedan
Old 02-13-2017, 12:55 AM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
ABS sensor is unplugged most likely. Make sure it is installed correctly, and is plugged in. Nice Brembos BTW .
Old 02-13-2017, 11:37 AM
Karl Horn's Avatar
Thank you! I just went and checked and everything is hooked up correctly. I'm gonna do a little test drive and then rebleed the brakes.
Old 02-13-2017, 12:06 PM
Karl Horn's Avatar
Filled the brake fluid to the max line and reset the ECU and all lights are out. Works like a charm!
Old 02-13-2017, 12:21 PM
Well let's see the rest of the car! Nice set up.
Old 02-13-2017, 09:02 PM
Karl Horn's Avatar
Old 02-14-2017, 03:43 AM
Some custom projectors... Brembo brakes... this G is getting the suite treatment. Glad it's all working out.
Old 02-15-2017, 07:04 PM
Karl Horn's Avatar
Just got my 05-06 JDM Taillights today to go with my JDM fog light/reverse light
Old 02-15-2017, 07:24 PM
Too darn cool. Post in the sedan thread, so it gets more attention. After all, the problem is solved here.
Old 02-16-2017, 06:38 AM
Blue Dream's Avatar
I drove ttrank's car solo
Received 1,486 Likes on 1,221 Posts
And a Nismo bumper to boot, great looking car OP.
