| New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login |
| Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Garage | Vendor Directory |
| Welcome to G35Driver.com! |
Welcome to G35Driver.com. You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join G35Driver.com community today! |
Thread Tools |
Display Modes |
Thanks guy's, glad to do what I can.
HOLY SHt!! you're the man!
I bow down to the G35 suspension guru. Gsedan35, we're not worthy!
EDIT: Someone make this a sticky, like NOW!
__________________
In case of contact with mouth, eyes or any mucous membrane area of the body, rinse immediately with clean water. |
Quote:
Awesome post
<---------- Bookmark's thread
__________________
2003 5AT BO G35C: Turbo XS exhaust, Strup Headers, MD 5/16" Spacer, UR Crank Pulley, Helix Test Pipes, 350EVO 3.9 Final Drive, Nismo R-Tune Cams, Uprev Osiris Reflash tuned by Shawn Church. |
Jim,
You possess an amazing knowledge of G & Z suspensions and components. Thanks for sharing it with us.
Great thread. Im curious, are these numbers exact and up-to-date? i get different drop and spring rates for the tanabe DF210 from different sources.
Quote:
"The DF210 coil spring offers a large drop, while retaining superb ride quality characteristics. The spring rate is raised 10-15% to compensate for the shortened amount of suspension travel, without over stiffening the spring rate and affecting ride quality and shock lifespan." Fact is, specs that show the DF210 coupe spring is Stiffer or softer then oem springs by F-2% R+3% , hardly 10 to 15 percent stiffer. I will change the rear DF210 coupe rear lowering spec to reflect 1.3" of rear drop. Last edited by Gsedan35; 09-28-2005 at 11:03 PM. |
What about on a G35c 2003?
Quote:
ya thats what I want to know thanks :O) for some reason I'm more lean toward the swift springs. Just wondering what you guys think of them.
Quote:
FYI
for info on Silk Road http://www.silkroad-usa.com/pages/rm8.htm standard spring rates : 10kg (F)/8kg (R). you can also spec your spring rate Quote:
__________________
Get UpRev'd at MunkyWurks PH: (808)848-8794 (Refer 636Racer) 2008 Nissan Titan SE KC SWB 4x2 2004 Infiniti G35 Coupe Last edited by 636Racer; 11-21-2005 at 04:40 PM. |
ty for the thread
| Tags |
| 2005, 350z, coilover, coilovers, dyno, francisco, g35, hr, install, installation, rate, san, sedan, shock, shocks, spring, springs, swift |
| Thread Tools | |
| Display Modes | Rate This Thread |
