*Special* Royalty Rotors Now Available!
Royalty Rotors are now available through US-AUTOTECH!
We are now officially a distributor of Royalty Rotors.
There will be a very special pricing for Rotors + Brake pad (Hawk Pads or Royalty's Semi-metallic) combos as well as free shipping to the lower 48 states.
These are direct OE replacement rotors available in Plain or Slotted Cross-Drilled.
Please Pm me for price and make sure to include vehicle Year/make/model-sub model and type of package.
OE Plain Rotor......................................... Semi-Metallic Brake Pads
More Info about Royalty:
Benefits of Zinc
Zinc plating is a valuable tool which is used to combat corrosion of steel. A metal bond is formed between the zinc and the steel, which allows the zinc itself to corrode before the steel. This way the zinc will be sacrificed allowing the steel to remain intact.
The basic principle behind electroplating is the process of depositing a metal layer on a metal base using a direct current through an electrolyte solution. Zinc is one of the easiest metals to plate, giving good corrosion protection without using exotic chemicals. The finish can be polished to give a shiny luster almost as good as chromium.
Zinc plated components are very attractive and provide a bright, smooth surface.
Replacement Rotors
Royalty Automotives replacement rotors are engineered to OE design and specifications. Our rotors are machined balanced for vibration free performance, minimize brake shudder and reduces brake noise and extends pad life.
Royalty Automotive rotors are vented for cooling unless OE rotors were solid form the factory.
Royalty Automotive OE Slotted pad design allows for heat and dust dissipation, thus ensuring top performance and durability. Royalty Automotives long life formulation extends life of pad, rotors and entire braking system. Low resin content means brake fade is virtually eliminated.
Royalty Automotives Chamfered pad design is OE for improved seating and long term performance. Our Shims mirror OE and provide enhanced noise reduction.
Royalty Automotives Semi-Metallic compounds ensure a strong performance under all road conditions and temperatures. Delivering a smooth quiet ride, and virtually no dust, without excessive rotor wear or brake fade.
Benefits of Zinc
Replacement Rotors
on
PM PRICE FOR '06 6mt coupe all four rotors slotted/drilled shipped to 91040
