Z1 350Z and G35 Rotor and Pad Upgrade Pkg. Brembo or Standard
Z1 Brake Upgrade Pkg. Brembo or Standard
Z1 Motorsports stock sized brake upgrade package for 2003+ 350Z or G35 equipped with the OEM Brembo or Standard.
This kit will take your stock brake system to the next level. If you are looking to upgrade your brakes but don't want to spend thousands on the many big brake kits available this is the kit for you!
This kit includes:
- ATE Super Blue Racing High Performance Brake Fluid for coping with the extreme demands posed by motor racing. Dry boiling point 280 degrees C (535F). Wet boiling point 200 degrees C (392F). Exceeds all DOT4 standards. 1 liter container. Super Blue Racing High Performance brake fluid is standard in this package, however you have the option to chose ATE 200 High Performance Brake Fluid or Motul RBF.
- Four Performance Rotors Cross Drilled & Slotted or Slotted only dissipate heat away from the rotors to reduce warping. Silver zinc plated to prevent corrosion and increase life. Double disc grinding ensures parallelism. Mill balanced (withing 150 g-cm) to prevent vibration.
- Stainless Steel Braided Brake lines (All Four)
- Your Choice of Brake Pads. AMS Carbon Ceramic Brake Pads are Standard, Centric, AXXIS, and Hawk pads are available as options.
350Z and G35 brake upgrade packages are in stock at Z1 Motorsports ready for shipment or installation.
This kit can be found HERE.
This complete package starts at $510
This kit includes:
