Stoptech big brake kit available..big discounts!!
A StopTech® Big Brake Kit represents the ultimate high performance brake upgrades and gives vehicles that supercar look and feel.
StopTech® Big Brake Kits exceed stock performance in two key areas: First, larger rotors increase heat capacity, allowing a driver to brake harder stop-after-stop with reduced chance of fade. Second, stiffer calipers and stainless steel lines reduce system compliance, providing consistent pedal feel and confidence-inspiring responsiveness.
The key, however, is to increase heat capacity and reduce compliance without upsetting a vehicle's stock front-to-rear brake torque ratio. That is why StopTech® developed the Balanced Brake Upgrade® design philosophy, which precisely apportions front and rear braking resources while factoring in vehicle weight transfer under braking.
In contrast, a brake upgrade that adds too much front torque (as many do), will reduce your car's ability to maximize the traction available from all four tires, robbing you of performance. In addition, a system that uses too many pistons or pistons that are too large will make the brake pedal much more difficult to modulate, limiting a driver's control of brake input.
Reasons for a StopTech® Big Brake Kit Features and Benefits:
•Balanced Brake Upgrades® with optimum brake bias offer the shortest stopping distance with the best pedal feel.
•Patented AeroRotors® offer the best airflow available for better cooling, less fade and longer rotor and pad life.
•StopTech® provides the stiffest fully-forged aftermarket calipers with patented, removable bridges that provide better clamping under hard braking and less pad taper.
•StopTech® Big Brake Kit components are made in the USA in a 70,000 square foot California manufacturing, engineering, and R&D center
WE WILL MEET OR BEAT COMPETITION PRICES... PM US OR CALL US DIRECT.
OFFICE HOURS:MON-FRI 9AM-6PM OR SAT 9AM-2PM
PHONE: 800-530-3514 OR TEXT: 714-616-7637
WWW.G35BRAKESOLUTIONS.COM
2002-2008 (g35 non brembo) $175 4 slotted rotors
2004-2006 (g35 brembo) $185.00 4 slotted rotors
others g35,g37 years are also avail inquire within
call us direct at 800-530-3514 or text 714-616-7637
office hours: Mon-fri (9am-6pm) or txt 714-616-7637
www.g35brakesolutions.com
2005 g35 Non brembo can I get a quote for 4wd and 2wd front and rear set up. Thanks
The best brakes and brake components at the best prices-all in one great site!
On the hunt for top-quality brakes, but don't want to break the bank? G35 Brake solutions is your one-stop online shop for the best brakes and brake components available in Premium line , E-line Rotors offering the best prices in town.
visit our websit: www.g35brakesolutions.com (for a complete listing of G35,G37 brakesolutions)
Call Toll Free: 800-530-3514
txt: 714-616-7637
txt: 714-616-7637
Jiggerjuice
08-17-2015 08:41 AM
