TUNERZ STORE | DBA 5000 Series 2pc Slotted Rotors and Replacements - AKEBONO Brakes
Old 11-06-2015, 12:02 AM
Tunerz_Store's Avatar
We have now added the DBA 2pc rotors and DBA 2pc replacement rotors to the line-up for the sport brakes
Excess weight is your auto's enemy. Though it won't lead to a case of drivetrain death, it certainly makes you sluggish—and that can spell the difference between taking first or eating the victor's dust. Cut your suspension's unsprung weight and crank up your braking strength with DBA T3 5000 Series Rotors.
Unlike most rotors, your DBA 5000s boast a two-piece design: hard-hitting rotor surfaces bolted to a featherweight hub. Each rotor features the exclusive tri-symmetrical slot design that serves up maximum vibration reduction for quiet, smooth and strong stops. Then, the reusable hub is carved from aircraft-grade T6 aluminum for weight savings and the power to swap out rotor surfaces without shelling out for new hats.
Designed to handle the heat of the track, your DBA T3 Rotors stay cool under intense pressure. First, they're built from XG150 high-carbon alloyed iron for greater thermal capacity. Then, they're armed with DBA's Kangaroo Paw venting system to speed up cooling. Lastly, they're marked with thermo-graphic heat paint so you can check their peak temps and keep track of wear. And, DBA backs ‘em with a 12-month/12,000-mile warranty.
Big bite and reduced weight. That's why you upgraded to DBA T3 5000 brake rotors in the first place. But, even the highest quality brake rotors are gonna wear out. Lucky for you, your DBAs feature a two-piece design. So swap those damaged DBAs the easy way—DBA T3 5000 Series Replacement Rotors. Built as a direct replacement, DBA T3 rotor rings mount right to your original Alumalite hats in a flash, so you can get back to winning.
Quick refresher. Your DBA T3 5000 rotor discs are the ultimate performance brake. Thanks to the Thermo Stability Profiling, they handle extreme heat under extreme conditions while dramatically extending pad life. Oh yeah, and there are those thermo-graphic paint markings that let you know if your DBA T3 replacement rotors are too hot, or not.
Of course, thanks to the patented the Kangaroo Paw venting, DBA T3 5000 rotor rings run cool as cucumbers. Up to 20% cooler than traditional rotors, in fact. All non-friction surfaces are coated with protective paint for style, and every rotor is marked with its part number, manufacture date and batch code for traceability, Cooler yet, DBA backs your T3 5000 Series Replacement Rotors with a 12-months or 12,000 mile warranty.
Notes:
Replacement rotor only — does not include Alumalite hat
Fitment:
Infiniti G37 Sport 2008+
Infiniti M37/M56/Q70 Sport 2011+
Infiniti Q50 Sport 2014+
Nissan 370z Sport 2009+
Any model with AKEBONO Sport Calipers
Old 01-04-2016, 08:13 PM
Best prices, best deals.
Old 01-13-2016, 12:42 AM
All pm's replied.
Old 01-31-2016, 05:19 PM
PM me for your best deal on any item we offer!
Old 02-25-2016, 12:56 AM
Your continued business is greatly appreciated!!
Old 09-21-2016, 04:00 PM
PM me for you best deal!
Old 10-12-2016, 02:08 PM
Old 11-07-2016, 03:49 PM
Old 11-29-2016, 08:57 PM
Thanks for the orders!
Don't forget to check out our monthly specials on the website.
Old 12-22-2016, 11:34 AM
Old 01-05-2017, 12:38 AM
Old 01-12-2017, 01:59 PM
Old 02-05-2017, 07:19 PM
Old 02-21-2017, 03:41 PM
Old 03-06-2017, 11:15 PM
Quick Reply: TUNERZ STORE | DBA 5000 Series 2pc Slotted Rotors and Replacements - AKEBONO Brakes
