FS: Rotora FC6 Front 355mm 6-pot Big Brake Kit Nissan 350Z Infiniti G35
• Powdercoated Red, with SS brake lines.
• Hawk Performance Brake Pads (HB109Z.710) just installed <1,000 miles ago
• Includes two sets of rotors: One-piece solid rotors, and two-piece Rotora drilled/slotted. Both are 114.3mm X 5 pattern.
• Includes mounting brackets that will fit Nissan 350Z and G35.
• If you can purchase the mounting brackets for your application, the Caliper should fit.
• No leaks or signs of seal wear. A few scratches/marks in powder coat from previous brake pad changes. These are minimal, and clean up nicely.
• One-piece solid rotors were purchased new a year ago, and were turned when the Hawk pads were installed
• Rotora two-piece rotors starting to show some heat cracks around the drilled holes. Still usable on vehicle, but suggest replacing the outer rotor rings.
• New this kit cost 2,695. Perfect working order. Will not be disappointed.
Asking: 900OBO (Paypal preferred)
Email: john.quick@me.com
Phone: PM for number
Thanks
Johnny
Thanks
Johnny
This is for the front only. Feel free to make a reasonable offer. They should go to someone who will put them to good use!
They measure 6" across at the widest point. 3" to center. If you measure from the middle of your brake rotor out towards the wheel, it will stick out 3".
They fit without spacers on my car, and I have the 19" OEM Rays wheels.
Hasanbaloch
02-29-2024 08:45 PM
vstypicals
07-20-2015 10:55 PM
