Thread Tools | Search this Thread | Rate Thread | Display Modes |
OBDII with StreetDeck
Does anyone have screenshots of what the OBDII scanner prints out on StreetDeck? RcDash, I read that you confirmed that OBDII works fine. Can you provide some screenshots? What does it display? Can you list all the items that it displays? I'm thinking of purchasing an obdII scanner to interface with this software. Thanks..
-twantrd |
Does the manual not display it? I use CIPHER now so I disconnected my Elm Scan. It's just sitting around. I thought I'd keep it in case my Honda ever throws a code...
The StreetDeck implementation basically allows you to monitor 2 parameters and it provides a running graph. It also allows you to clear a code (never tested it for that). |
rcdash, any input on good programs for the elmsan5? I just bought one a few days ago and am trying to figure out which is the best. Any input is appreciated.
__________________
04 IP Coupe - Custom Carputer w/DW Touchscreen, XP, GPS, Centrafuse, MameArcade..etc.-Compustar Alarm - Ground Kit- 5/16 Iso Spacer - Greddy Sp - 4080/JL Setup-& more. Carputer Thread- http://g35driver.com/forums/car-pc/45823-g35-coupe-carputer.html Carputer2: http://g35driver.com/forums/car-pc/85160-my-2nd-g35-carputer-creation-install.html |
i've only used proscan (www.myscantool.com) and I was impressed by the "extras", but the diagnostic functions didn't seem that great - had a code once due to ECU battery failure and it gave a P0000, but the dealer got a more specific code that specified the true fault (from the battery being disconnected an extended period of time during stereo install).
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
