So you have seen my garage PC, now my carPC
Old 07-03-2012, 05:04 AM
Vimana's Avatar
Just want to say thanks for working this out. Followed your description to get ours working similar. We have the factory reverse camera so i wired the 4TDP relay up using accessories one side through a switch and the otherside the positive of the reverse lights. This means when the car is pit into reverse the relay switches back to stock screen for the camera. Can also be overridden via the switch.
My only problem is the rgbsync converter i used does not have a battery backup onboard so it wont remember the contrast and brightness settings. I might just use an old phone charger to give it permanent 5volts to keep its memory. Im sure its current draw wont be too much.
Old 07-03-2012, 08:08 PM
UCIMAplaya2's Avatar
i dont think mine has a memory for those settings either. I am doing all that from the pc video card settings. As for the current draw, you should be safe. these draw almost nothing when on
Old 07-03-2012, 08:15 PM
Vimana's Avatar
I want aware and couldnt find brightness/contrast settings in the video card. Its usually done on the pc monitor. Are you adjusting a windows setting or ati/nvidia software?
Old 07-08-2012, 12:54 PM
nvidia. I actually bought this little nettop because it had an nvidia chipset with such control
Old 07-03-2013, 10:51 PM
G_DiRTY5's Avatar
Sub'd!!
Old 07-04-2013, 01:32 PM
Originally Posted by G_DiRTY5
Sub'd!!
Good because I am preparing to install a DD touchscreen in place of the factory radio and lose that all together. Just want to get a few things updated on the PC and then get a new amp and speakers for the car.
Dallsinghjr1
09-17-2023 11:25 AM
Duffy25
Accessories
10-12-2015 01:45 AM
toadfire
09-21-2015 07:15 AM
DRG35R
09-16-2015 05:33 AM
Quick Reply: So you have seen my garage PC, now my carPC
